How to stream Tidal Masters from IMac to Muso
Posted by: Stujbro on 05 April 2017
Is it even possible to do this? I've just bought an iMac and am inexperienced with the iOS system. My muso and iMac are connected via Ethernet switch and cat6 cable but I've no idea how to stream to it directly.
Posted on: 05 April 2017 by blythe
On your iMac, go to System Preferences.
There, click on "Sound" with the little icon of a speaker
Click on the "Output" tab
From there, a drop down list of all available speakers should show, including your Mu-so
Select your Mu-So and your sound will now eminate from the Mu-So via AirPlay
Posted on: 07 April 2017 by Dan.S
And voilla, you'll have an allegedly good source ruined through airplay.
Posted on: 07 April 2017 by Stujbro
Is there a way to hardware the connection?
Posted on: 09 April 2017 by blythe
If you plug your iMac optical output (if it has one) directly into the optical input of the Muso it should also playback through the Muso.
To be honest, although Airplay is not the last word in hi fidelity, for playback through a Muso, I suspect you'd be happy enough with the results.
Posted on: 09 April 2017 by Adam Zielinski
You'd need to run UPnP software on your Mac and access the content this way.
Using NAS is a far more common way of streaming to Naim streamers.
