FLAC file size and disk sizing?
Posted by: Judge on 11 April 2017
I am about to embark on a project to move to streaming my CDs... to start with I can stream to my Marantz AV equipment which is integrated with my stereo Naim Hifi. So before I invest in a dedicated network player, that will do while I get the other hardware and software needed in place.
To start with I have decided to go the NAS route, and need to size the disk drives (so I can run in RAID). At present my total (iTunes) music file is just about 100GB, mostly highest quality MP3, but some ALAC (basically for my iPod). However I did do some A to D conversion of vinyl with the intention of digitising my favourite LPs. I created some FLAC files in the process and if I compare them with the MP3 files of the same tracks they are about 15 times larger. That means if I upload every CD again as FLAC then it would need about 1500 GB or 1.5 TB, so I am thinking 2 x 2TB disks would be okay, but 2 x 3TB disks aren't that much more expensive and represent a better choice. Also I reckon about 10% of my collection might never get converted, but I might eventually buy HD music and that would need more space still so the larger disks give greater capacity for that.
Is the ratio of 1:15 about right and if so does my conclusion on disks size/cost seem appropriate?
Thanks.
