Pmc Twenty 5.22 or Ovator S-400 Maybe Atc
Posted by: AirKing on 17 April 2017
Hi everyone, I'm pretty new to the forums.
Please  can I get some advice, I currently have the Pmc above, they sound great, the highs and midrange are lovely, but I have this feeling that I am missing something in the sound.
I was hoping the sound would be a full hearty type of sound but seems quite midrange, sorry can't quite describe it properly, the bass is very good at low volumes, but not very controlled if I turn the volume above 50, the stands are filled around halfway.
I sit around 7ft away from my listening position.The room size is 16ft long by 10ft wide. I sit width ways not length ways as I find the bass is not enough length ways, hence my listening position only 7ft away,
My equipment is a Nac-272 and a 250Dr, Rega RP8.
im just wandering If I change to the Ovators is this going to be overkill, or will I be getting a fuller sound compared to the Pmc, I would have to by the Ovators bling as can't find a dealer who has them locally to borrow, but have noticed you can get them around the £2k ish mark second hand. Or has someone have  any thoughts on Atc Speakers, floorstanders?
Anythoughts or ideas would be much appreciated, hope I haven't bored to many people with my questions.
Posted on: 17 April 2017 by GraemeH
Hi AIRKING - I changed from twenty.23 to S400 and now use them with 272/250DR & TQB 'speaker cable. The S400 is a much more revealing speaker than the PMC's, which I like very much. Very room dependent though. I bought blind S/H and was just lucky I guess.
Posted on: 17 April 2017 by AirKing
Many thanks
GraemeH posted:
thanks for the advice.
