Fraim Setting Out
Posted by: northpole on 30 April 2017
I'm sure this will have been done to death over the years but my search skills are not up to scratch.  Is there any concensus on the minimum sensible distance from the back leg face to the wall behind to ensure cable dressing is achievable, particularly burndies and hi-lines?  Positive comments greatly appreciated!
Peter
Posted on: 30 April 2017 by Robiwan
back wall to front about 53 cm is enough.
Posted on: 30 April 2017 by KTMax
I think that depends on the cables used as well. Standard power leads require less space than thick fat power cords etc.
Posted on: 30 April 2017 by northpole
Thanks for the replies Robiwan & Ktmax.  The 552 & 500 burndies seem to be the biggest space takers and the hi-lines just make me a bit nervous with their candy-floss 'robustness'!!
Peter
