Best Tidal Playlists
Posted by: Kevin Richardson on 08 May 2017
I would like this thread to be a place where people can share Tidal playlists.
Posted on: 08 May 2017 by dayjay
How does one share a Tidal playlist?
Posted on: 08 May 2017 by Kevin Richardson
https://tidal.com/playlist/65a...d7-a904-8644b98fe59b
This playlist was used by Naim at "The Bristol Show 2016"
dayjay posted:
In the Tidal app, select the playlist and press the "3 vertical dots" button at the top right and you will get a list of options. Select share. On my iPhone I can then select "copy" to get the url. You can then paste it into your message.
