NAC 52/Supercap
Posted by: mlauner on 11 May 2017
I have an opportunity to purchase a 17 year old Nac 52 and Supercap. I can only afford getting one serviced now. I am assuming the supercap would be the logical first choice?
thanks
Posted on: 11 May 2017 by varyat
Congratulations- its a wonderful preamp.If only one box can go, then yes, make it the Supercap. Personally, I would try to have both serviced at the same time to hear all the goodness at once  !
ATB,
Mark
Posted on: 11 May 2017 by lyndon
think the most important thing here is you make sure you get the 52
you wont regret it
lyndon
Posted on: 12 May 2017 by jeff kleinberg
Does it have pots 8 and the latest hardware?
Posted on: 12 May 2017 by Christopher_M
jeff kleinberg posted:
Jeff, You've reminded me of when I delightedly told a Naim mate that I'd finally found a good pair of SBLs. His response was 'are they Hornslets?'
Chris
Posted on: 12 May 2017 by mlauner
NAC 52 dates from 1999 which was prior to pots 8 I believe.
Posted on: 12 May 2017 by Eoink
They could be upgraded (and still can) to POTS-8, so it's worth checking. I had my 24 year old 82 upgraded to POTS-8 in April this year.
Posted on: 12 May 2017 by Aceone
Is the nac 52 better than the 252.
