Naim recap kit for Nait 1
Posted by: dunnoguit on 13 May 2017
Just had my Nait 1 recapped by Naim distributor and seemed only 7 caps plus two other little things have been replaced. Checked and got a reply saying that's Naim recap kit. Did I expect too much?
Posted on: 13 May 2017 by Richard Dane
That sounds about right. The only other thing that may get replaced is the volume pot if the original is noisy.
Posted on: 13 May 2017 by dunnoguit
So that means these 7 caps are only ones that will potentially go bad?
Posted on: 14 May 2017 by Richard Dane
If you want the full lowdown on what work is done and which components are usually replaced during a NAIT service then you could email Naim and ask them.
They recently serviced my own NAIT and also replaced the volume pot, however I'm working today so can't look for the service summary to tell you which exact components were changed.
