BT Smart Hub
Posted by: NewNaim16 on 16 May 2017
Hi - Does anyone have the power consumption of the new BT Smart Hub please? I'm considering a possible change from our BT Hub5 to hopefully give improved coverage in the far corners of our not so vast home. The Hub5 is marked 12v, 1.5A on the underside so presumably is consuming up to ~18W, it feels like that to the touch
I saw that some other forum members had ordered the new Smart Hub but couldn't find much feedback. Is there any experience out there either +ve or -ve?
Posted on: 16 May 2017 by Harry
I got one when fast fibre arrived in my village. It replaced a HH3. i've just had a look on the back and the bottom and there is no info on anything other than passkeys. I already had repeaters and I still need them. I don't think the Smarthub has a better WiFi range in my house, although all my internal walls are thick and made of masonry, so they are very good at signal attenuation. The device appears less flaky than the HH3, although that could be down to line quality. No complaints. easy to set up. Wouldn't put it up for Pope but there's nothing essentially wrong with it. The HH3 went upstairs and is a very nice little repeater. Works a treat and has opened up the first floor.
Posted on: 16 May 2017 by Mike-B
Hi Newnaim, don't take the SMPS watts rating into account,  their are two variants of BT HH5 & each has a different SMPS, but none get close to the max rating, it's in the 7 to 10 watts range depending on what it's doing (it's not constant).   I'm away from home at the moment but have all the info on file & can get back on Friday.  I have a HH6 coming soon so will look that up as well - if I can find it
Posted on: 16 May 2017 by audio1946
10 watts. excellent, best wireless signal through out indoors and in garden, muso plays without a glitch outside
Posted on: 18 May 2017 by NewNaim16
Thanks all, I appreciate that power consumption depends on the activity but just wanted to have some level of confidence that a new BT Smart Hub [Hub6] won't consume a huge amount of additional power compared with the Hub5 but it sounds as though they're at least in the same range.
Mind you, I've no accurate measurement of what the quiescent power consumption of my Naim gear is but one day I'll get to measuring it.
[@mention:1566878603907884] any additional info when you're back home would be appreciated.
Posted on: 18 May 2017 by Slim68
Hi
A few months ago I changed from the HH5 to a Smart Hub, in my experience it is a much more stable unit with a larger Wi Fi range.
This may help in your quest for Information;
 http://www.productsandservices..._hub_test_report.pdf
All the best, Simon.
Posted on: 18 May 2017 by jonnaim
Why are you bothered about electricity consumption of bt HH? if you can afford naim hifi you should not be worried that your electricity bill will be £11.73 higher because of the HH you use!
Slim68 posted:
Hi
Thanks for the interesting link Simon.
jonnaim posted:
My question was not really anything to do directly with affordability but if you can't measure something then you can't manage it. For example, I have two dehumidifiers running 7x24 which for me is worth it but if the new BT Smart Hub took say another 50W of continuous power consumption then I wouldn't bother with it. Make sense?
Posted on: 18 May 2017 by Mike-B
NewNaim16 posted:
I can't find much on the HH6,  the only numbers I can find don't have a decimal point so I suspect they are a bit 'approximate'
Anyhow your question was how does it compare to HH5  .........it looks like diddly squat difference
Two versions of HH5 - Type-A & Type-B
 BT HH5 Type-ABT HH5 Type-BBT HH6 SmartHub
In operation9.2W14.0W11W
Idle6.3W7.2W7W
Diddly squat difference is good. Thanks very much Mike.
Posted on: 10 June 2017 by Mike-B
My BT HH6 arrived last Monday.   Its installed on its own SMPS rather than the iFi iPower (for the time being anyway)
Its working perfectly,  no obvious changes between it & the HH5 in performance in 'normal' use,  however it does have an extended signal range, in the garage which was a blind spot & goes further into the garden area.
It has a more 'idiot proof' Hub Manager with less bits to fiddle with & less radio channels to select (if you choose not to use the BT 'Smart' auto channel feature).  So whilst its got less programmable features to fiddle,  as a consumer unit it does work well straight out of the box with its 'Smart' features,
I've split 2.4 & 5GHz bands,  this is an easy to do on/off feature with the Hub Manager & it even renames the 5GHz band SSID automatically by adding '-5'.       I have the 2.4GHz channel on 'Smart' but fixed a channel on 5GHz.    Also turned off  'Smart Setup'  which is a nuisance once the initial set up is done.
I've reset all my equipment including the audio from 'Static' (always use this IP address)  to normal DHCP,   the HH6 does not switch around IP addresses & keeps previously used addresses providing they are within the BT license numbers group.   This better facilitates IPv6 I believe,  plus its letting the hub do all the brainwork.
I'm waiting to see if the 5GHz line speed drops off as it did quite frequently with HH5  (a hub restart fixed this)    As expected line speed remains the same as it did with HH5 - its a 80/20 service & I get around 74/18.   Also waiting to see how often BT change the remote server which they did every 7 to 10 days before.
Posted on: 10 June 2017 by Ravenswood10
I'm on my 5th Smart Hub in 5 months with previous ones all suffering from the amber or green lights of death. Customer support has been appalling but improved when I finally got through to Executive Level complaints in Newcastle. It a nice unit when it works and the improved wireless range is clearly a bonus. Keeping my fingers crossed that this one keeps working. I'm also holding on to my HH5,just in case.
Posted on: 10 June 2017 by Simon-in-Suffolk
NewNaim16 posted:
Hi, just an observation, if you have multiplie devices accessing your wifi across significantly different signal levels, then having a single wifi access may not be the best idea, as it might encourage devices on the wifi network to unduly interfere with each other choking off performance. So if you have a larger space with multiple wifi clients of differeing signal levels, then having two, three or more lower power wifi access points working as a single ESSID ( absolutely not the the same as using atrocious wifi extenders) is the way to go and you will most likely see a hugely better wifi performance. This is similar to what many commercial setups do. The UniFi products are one example of how you could do this and are relatively inexpensive. You would connect these accesspoints to your BT hub of what ever description and disable the hubs wifi.
Simon
Posted on: 10 June 2017 by Gazza
I use an amped wireless product from the U.S which I picked up on amazon global, does exactly what Simon mentioned. I have an ethernet run to an office in the garden and it provides the wifi for that building.
Posted on: 11 June 2017 by NewNaim16
@Mike-B: Thanks for the report. Although our Naim gear is Ethernet hard wired, the potential for extra Wi-Fi range from the new BT Smart Hub / HH6 will be useful for other purposes. Time to order one methinks.
@Simon-in-Suffolk: Point taken about multiplie devices accessing your Wi-Fi across significantly different signal levels, however that's not the issue. Its simply a longer distance in a weird house with the radio signal going through a double thick brick wall. I looked at the UniFi products which are very interesting, I 'think' we used them at work. However, I'm hoping that the new BT him will do the trick, its just a signal strength connectivity issue.
As a side comment, our BT Hub5 has been totally reliable - except of course when BT are going though one of their fairly regular configuration exercises!
Posted on: 11 June 2017 by Simon-in-Suffolk
Got you - well in which case the new BT hub could be your answer - it seems to score  better against its competition if you believe the adverts
Posted on: 11 June 2017 by Ravenswood10
As before just watch the reliability issues. I've had to instal a new one each week due to reliability issues and have had to fight hard with customer services in India to have them replaced.  My last session them lasted an hour and involved being handed off to three people two of whom asked me why I wanted a HH6! In the end I wrote to their new CEO and within a day it was sorted and a full refund provided too.
There is a known issue with them which often results in frequent drop-outs and worse still getting stuck with what the BT forum calls the green or amber lights of death. My latest one is said to be from new stock and has worked fine for the past week. When they work they're great but 5 failures seems extreme to me. If this one goes it's back to the HH5 or a third party router.
@Ravenswood10: Thanks, I appreciate the input and will check the BT forum first to see what constitutes 'new stock'. Somehow that reminds me of the poem, "When she was good, she was very, very good but ..."
I forgot to add that, the one thing BT fail to compare adequately the performance of their new BT Smart Hub / HH6 with on their published comparisons, is their previous Hub5. I find this a curious feature/advantage/benefit omission.
Wireless range aside I've found the HH5 to be more stable and reliable. The BT forum also suggests as much.
Thanks much. Since this is not an urgent situation, it may be a case of caveat emptor and also seeing if Mike-B has any issues before I commit.
This is only so that Mrs NewNaim16 and myself can have better Wi-Fi connectivity in one particular room from where we often access the Internet during our DAT (Daily Activities and Tasks) breakfast meeting. Don't you just love retirement!
Great when it works though. Just hope they send you a good one
Posted on: 11 June 2017 by Harry
Mine reboots and goes through the orange and green light show about once or twice a week. I assumed it was just doing an update. It's not dropped me off for more than five minutes max. I'm grateful to hear about this potential fault. Forewarned and all that...
I have an HH5 standing by for emergencies.
Always keep the trusty HH5 - mine was pressed back into service no less than four times. The green and amber lights of doom stay on for hours on end and terminal
Posted on: 11 June 2017 by Pev
I've had a Smart Hub/HH6 for a few months without any problems at all - it replaced a HH5 which was also fine - unlike the HH2 and HH3 I endured. Both the speed and the range of wifi is very much better - possibly because of its AC support.
I've had my problems with BT but have found that it's fairly easy to get a substantial discount if you haggle just about the time your contract is up - asking for a MAC code usually does the trick. I've also found that they are very ready to throw in a free hub upgrade as part of the deal, that's how I got mine. My haggling skills are much improved since watching Shed & Buried on the Travel Channel.
