Supernait 2 protection circuit
Posted by: 1stName on 18 May 2017
I have a Supernait 2 feeding the high frequency of my T + A Criterion TCD 210 S speakers and a NAP 250 feeding the bass (bi-amped off the Supernait 2) with two 5m runs of NAC A5 cable.  All works very well until I turn up the volume (to just less than halfway) when occasionally, the protection circuit is triggered.  I'm thinking of upgrading to a NAC 252 and adding another NAP 250 to continue bi-amping as I know the 210 S are not an easy load to drive - does anyone know if this setup has a similar protection circuit or if I'm less likely to have this issue?
Posted on: 19 May 2017 by james n
Have you tried swapping the amps over so that the SN2 is driving the bass section and see if the problem persists.
If you go the 252 route, a 300 (if able to drive these ok) would be a better way to go than bi-amping with a pair of 250's.
Posted on: 19 May 2017 by Huge
Have you tried single wiring using just the NAP250?  In general, with a NAP250 or above you needn't worry too much about the nature of the speaker; provided that you have at least 3.5m of NAC A5, they'll happily drive a 2Ω load.  With some speakers, bi-amping can cause weird interaction effects.
Posted on: 19 May 2017 by 1stName
Thanks James N and Huge, I'll try your suggestions to see if it makes a difference.  I bought the 250 because the Supernait cut out before and I thought having two power amps would help by sharing the load.  I think just the 250 on its own will be OK as its' the Supernait cutting out and muting the signal to the 250 as well.
Out of interest, why do you recommend the 300, is it just better suited to the 252 or is it a completely different design?  I did think of buying a 300 but as I mentioned above, I thought bi-amping but be a better for my speakers.
Sorry, I meant to ask if I need change any settings/sockets on the Supernait if I'm just using it as a pre-amp?
Thanks again.
No, just disconnect the speaker cables from the SN.  You need it's own power supply connected and to keep the link plug as you need it to power the preamp itself.
Posted on: 25 May 2017 by 1stName
Thanks again HUGE, your suggestion worked a treat!
