Pre amp display
Posted by: True Blue on 18 May 2017
Simple question. I have managed to misplace my pre amp remote which normally would not be an issue. However the display lights are still on.
I have my ndx remote in hand and system automation is connected....any ideas if I can turn the pre display off without the pre remote??
Posted on: 18 May 2017 by hungryhalibut
Best get looking.
Posted on: 18 May 2017 by Pcd
Time to pick the sofa up and give it a good shake.
Posted on: 18 May 2017 by Cbr600
Sounds like a trip to your Naim dealer is on the cards, to borrow a remote for a day
Posted on: 18 May 2017 by True Blue
Thanks. So doesn't appear to be possible? ? Trouble is I work away. Came home and wasn't where I normally keep it. Cue ocd rant. Of course no one else has moved it......
Posted on: 18 May 2017 by Christopher_M
Worth an email to Naim. I have a feeling there may be way of doing it from the front panel buttons alone.
Posted on: 19 May 2017 by Huge
True Blue posted:
... Cue ocd rant. ......
Perhaps you need to organise that in alphabetical order and have a CDO rant to straighten things out?
Another option may be to get a Logitech Harmony remote and that'll control all your a/v stuff from one remote, and they download the codes for Naim remotes from the internet (I can't guarantee that it'll have the reset code, it depends if somebody's programmed it, but it's likely to be there even if just in the command mode rather than pre-programmed to a button).
