Ns01 has started to be unavailabel in the morning
Posted by: Claus-Thoegersen on 19 May 2017
Or when I come back to it after I have been away for some time, usually when I want to play muisc the next day.
Am I the only one who has started to get t this problem in the last week.
Something strange has begun to happen, when I come back to listen to my ns01, after having been away over the night. Before this has not been a problem. The server is still on the network. But the last 2 days has been different. DTC cannot connect to the server. It can see the server, but when I try to connect I get the folowing error:
Failed to connect to the hard disk player located at
192.168.87.109:
N-serve cannot play contents from the server. If I look at the http page, there is also an error.
If I ping the a ip address there is no problem, all 4 packages are received.
So the server is on the network, but is not available.
A restart of the server solves the problem, but something is not working as expected.
The dtc is run on a Windows10 64 bit machine Creators update (build 1703. updated with the latest updates from MS.
Claus
