Nait 5si picking up unwanted radio signal
Posted by: roland150 on 21 May 2017
Hi all,
I hope that you can help me look into this issue. My Nait 5si is picking up some radio signal (I think it's from a nearby radio station) and it is driving me crazy. The radio signal is not subtle at all, it is LOUD, it is present even when volume level is zero and even when no other components/sources are connected to the 5si (just the 5si and the speakers).
Meanwhile, another amplifier of mine, the entry-level Denon PMA-520AE, is absolute quiet (no radio signal heard).
I just did a quick search on this forum and it seems that some other Naim gears can also have this issue to some extent. I saw an advice to put a ferrite clamp on power cord but not sure if this is the right solution.
Could you share your experience and solution of this issue?
Thanks a lot!
Posted on: 23 May 2017 by Happy Listener
Is there a plasma or large screen TV anywhere nearby and/or plugged in to the same supply circuit?
If so, suggest unplugging and see what this changes.
AFAIK, most of these RFI issues are down to wires/kit acting as radio aerials (hence the ferrite ring acts to subdue/remove). IME, large TVs can be peachy quasi-aerials!
Posted on: 23 May 2017 by Mike-B
I doubt very much if a ferrite on the power lead will help,  ferrite(s) on the signal input cable(s) might be useful.  What is connected to the amp (your profile page is empty - hint)   ".....even when volume level is zero and even when no other components/sources are connected....."  indicates it's being picked up by the speaker leads & because the Naim & Denon have different  output stage stabilization methods would explain the differences,  but that said it must a powerful transmitter thats doing this,  its far from common & a lot of happy Naim users don't get this:  were do you live?  & can you identify the radio station ?
Posted on: 23 May 2017 by Huge
Mike, thanks for starting to asking the questions.  I was just so frustrated by utter lack of any useful detail this post that I couldn't respond.
Posted on: 23 May 2017 by Richard Dane
As Mike says it must be a very powerful transmitter - are you in the UK or elsewhere?  Have you spoken to your supplying dealer?  What speaker cabling are you using?  Is it properly terminated?  How's the system earthing?  What else do you have connected to the system? Have you tried with and without anything connected?
Huge posted:
Mike, thanks for starting to asking the questions       ..........................
I was over excited with the prospect of ferrite farming again ...........  who can resist those dear little bundles of furry fun.
Seriously I am interested as its most likely a radio problem.
Posted on: 23 May 2017 by Simon-in-Suffolk
Hi, yes this is usually referred to as Radio Breakthrough (RFI is typically something else) and as suggested is probably down to the type, length and orientation of your speakers and speaker cables. Try changing perhaps temporarily the speaker cable runs or orientation to see if the breakthrough goes.
Simon
Posted on: 25 May 2017 by roland150
Richard Dane posted:
Sorry guys, here I am to provide more details about this situation.
There is an actual big transmitter about 200 metres from my room and the 5si is picking up the FM 89 Mhz channel, very loud and clear. I tried earthing and tried ferrite clamps - nothing changed.
My speaker cables are the ordinary copper ones with gold-plated plugs and conventional rubber wrapping. I am considering changing to higher-grade cables to see if this problem goes away, but the question is these very same cables did not pick up any radio signal when tested with the Denon amp, so can I safely say that the trouble lies somewhere else?
I am also contacting Naim for support and they seem intrigued that my 5si has this issue because it was tested before reaching the market, and that the Denon is immune although in the same system.
Posted on: 25 May 2017 by james n
Wow - that's close. You'll find the slightly different output stage configuration of each amp will make one more susceptible to RF pickup via the speaker cables.
What length are the cables and what type are they - you don't want to make the problem worse by having lengths that are resonant at the strong signal frequency.
