Does Anyone Own Two Systems Based On Naim Amplification
Posted by: ryder. on 24 May 2017
I noticed that few here own more than one Naim-based system and was wondering if there is anyone here who has two systems based on higher level amplification. I have the NAC 282 / NAP 250DR /HCDR and NAC 202 / NAP 200 in two separate systems and noticed that there is a member who has the same setup. I am aware that another member has a NAC 252 in the main system and a Supernait 2 in the secondary/bedroom system.
I was just wondering. Does anyone here have two systems based on higher level preamps? For instance, the NAC 552 and NAC 252, or the NAC 252 and NAC 282. We often read about views that separate the 252 and 282. Some would suggest that one would not be able to live with the 282 if he prefers the 252, or vice versa. I am curious if there is anyone here who has both 252 and 282 in separate systems.
Posted on: 25 May 2017 by kuma
I run 500/552 & 300/52. Does that count? I used to have a 252.
Posted on: 25 May 2017 by ryder.
kuma posted:
Thanks for that. It's good to know that there are folks who use larger Naim amps in separate systems.
Posted on: 25 May 2017 by ken c
52/135s/Kans
552/500s active/SL2s
why do you ask? just curious?
enjoy
ken
A matter of interest.
I am particularly curious if there's anyone who has both 252 and 282 (or 552 and 252) since there were few comments that suggested "once you listen to 252 there is no way you can live with the 282", something along those lines.
Posted on: 25 May 2017 by Nagual
i run 552 + 500 in the main system 95% of all listening.  the 552 was a magical leap form the 252 - as it should be £££.  I liked the 252 a lot but missed some of the raw excitement i got form the 282 it replaced. my 252 + 300 system is in another room and is massively under utilized - should probably be sold - but i probably wont part with it
Posted on: 25 May 2017 by hungryhalibut
ryder. posted:
That sort of comment is just silly. I'm perfectly happy listening to the Qb in the kitchen.
Posted on: 25 May 2017 by analogmusic
I've heard 252/300, and more than happy to continue with my 282.
I regularly listen to my friends 552/500 system, and don't feel any urgent need to upgrade my 282/HCDR/250DR, not until I win a lottery.
I would sell the QBD76, and buy a Hugo 2 though. Much better.
Posted on: 25 May 2017 by J.N.
500 series system into Kudos T88 Titans and (newish) Nait level electronics into Quad ESL 57's.
John.
ryder. posted:
ryder,
It's been a while since I demo'd 252, 282 back to back but I see why those 2 pres get a polarised opinion. 252 is more grown up and further lower the noise floor from a 282, so you get more details. At that time, I also borrowed Linn Klimax and recall it was on par in terms of resolution and generally how it carried on a tune. They were both good, i thought, but they did not offer anything different from other solid state preamps I have auditioned prior. (FYI: I've used a SC with 282 mostly as I thought just a NAPSC alone wouldn't be a fair comparison )
A 252 is more organic, the image moves up closer to a listener ( they are here rather than they are there perspective) gave me a *breathing* presence which I liked. OTOH, tho, it can sound less exciting ( I reckon due to a longer note decays over 282 ) and too laid back for some which I certainly understood.
I could easily live with a 282/SC in my office system but my recapped 52 can give me that similar level of *fun* for a lot less.
Posted on: 25 May 2017 by Erich
Hungryhalibut posted:
ryder. posted:
Fully agree with you HH. I have 4 Naim kits:  Music room, wife's atelier, sitting room and office; 252/250, UQ2, V1/200 and Qb respectively.  I enjoy all of them. For "serious" listening I prefer the music room.
kuma posted:
ryder,
Kuma, thanks for the post. Interesting remarks on the close-up image and longer decays of the 252 over the 282. I presume the "other" solid-state preamps other than the Linn Klimax that you auditioned must be high quality gear being able to match the performance of the 252.
Although I don't have the Supercap with the 282, the 282/HCDR sounds "high quality". The SCDR is quite a considerable outlay, and in my mind more suited to the 252 than the 282 (higher gains with the 252, lower gains with the 282).
analogmusic posted:
I happen to be in the same boat, with regard to happily continuing with the 282. :-)
As for the Chord, I don't think I'll see the QBD 76. However, I might consider the Hugo 2 at some point in the near future for the main or 2nd system (it depends which will sound better, the QBD 76 or the Hugo 2). Did you compare the QBD 76 and Hugo 2? One thing I don't like about the Hugo2 is it does not have a USB Type B connector.
Nagual posted:
I can understand the 252/300 is massively underutilised since you have the mighty 552/500 in the main system. Somehow I always have this concern about smaller systems not getting much use since the larger system will almost always sound better. The listener will usually gravitate to the bigger system which is able to provide higher levels of enjoyment and satisfaction.
I have toyed with the idea of setting up a 3rd system but after thinking about it for a while, I suppose it makes more sense to just maintain the current configuration as the new system may just end up underutilised.
Posted on: 25 May 2017 by nigelb
I demoed the 282 and 252 back to back when I was considering an upgrade to my 282. I already used a SupercapDR on my 282 so was able to slip the 252 in for direct comparison.
In reality when the 252 went in, the 282 never returned and was used as part exchange. Not because I didn't enjoy the 282 but simply that the 252 got me closer to the music and musicians. Kumar describes it perfectly.
As I only have room for, and can only afford, one main system, I would never run a 282 and a 252 together. I can imagine having a MuSo (or Atom) as a second system in say the kitchen. But a 252 and 282 in the same household makes no sense to me.
ryder. posted:
Ryder,
Other solid state preamps I have auditioned were mostly the usual American suspects:  Krell, JRDG, Boulder, Bel Canto, etc... plus Brinkmann, Halcro. Note that I did not use a Naim amp for these preamp demos. ( I used a pair of SET monos  or Krell amps)
I agree. A 282/NAPSC is quite good. Altho I could hear a difference when I added a SC, I thought that improvements weren't worth the money.
Posted on: 25 May 2017 by yeti42
My CDX2/282/Hi/250-2 and Thiel CS1.6s have moved to our flat in France. I thought lesser Naim might be a disappointment after the 552/500DR but the system is just as enjoyable as ever.
Posted on: 26 May 2017 by Adam Zielinski
I run 5 Naim systems in total - does that count? 2 of them are Uniti-based though...
As to 282 vs 252... Let's put it this way - I kept my SuperNait2 and sold 282 in favour of 252.
Posted on: 26 May 2017 by nigelb
Adam Zielinski posted:
Now Adam, that is just showing off.
nigelb posted:
Sorry
Posted on: 26 May 2017 by ryder.
That does count... as a huge Naim fan! You just surpassed Erich's record of having 4 Naim amplifier-based systems in total.
nigelb posted:
A 252 and 282 in the same household may make little sense but it can be a possibility if space and affordability are not a problem. There is already someone here who owns both 552 and 252 but the issue or concern is more about the "lesser" system being underutilised.
Posted on: 26 May 2017 by Skip
Guilty:
500 system.
Nait XS system.
Unitiqute. (Son's dorm room actually)
MuSo.
Posted on: 26 May 2017 by MangoMonkey
NDS/552/300
272/250
uq2
