NaimUniti - delivery times
Posted by: osprey on 15 August 2011
Hi all,
Does anybody have any recent first hand experience about NaimUniti delivery times? I placed my order mid May and am still waiting...
Thanks,
Mika
Wow, that's a very long wait. To state the obvious, I'd get on to the people you placed the order with and ask what's happening. I think mine took about three weeks. Thanks!
I have asked about status of the order regularly (in every couple of weeks) from the local dealer. When I made the order I was told that the delivery would be within 3-4 weeks. Later they even confirmed the shipment date to be June 10th but since then nothing. Last time I asked the dealer said that they will inform me when they will get anything further (indirectly indicating that don't call) and this did not sound very promising unfortunately. However, I still hope to get this piece of equipment someday.
- Mika
Something goes obviously wrong.
I would ask the distributor (you are in Finland, right).
The order has not been processed correctly or forgotten, or there is a mis-understanding between the dealer and the distributor.
Please ckeck again with your retailer, I am sure there must be an admin issue somewhere.
This wait is not normal.
Thanks for the advice Paul, I shall do that later this week. However, last time I asked couple of weeks ago they assured me that everything is in order that I just have to be patient.
Manu, thanks for your comment. I am currently already dealing with the distributor here. You know there really are not any choices in this area (you are correct in Finland) if I have understood correctly.
- Mika
Osprey,
Paul jumped in, you will have your Uniti soon.![]()
I just got the information from the dealer that the Uniti I ordered has finally arrived. However, the n-Sats I ordered at the same time (mid May) were not delivered. Furthermore there was apparently a note with the delivery that they are not anymore available at all (not part of current product line). Is this really the case? Anyone has an idea what is going on?
