Sky+ remote volume control for NAC52?
Posted by: Phil Cork on 16 August 2011
Hi, has anyone managed to find a suitable (surrogate) tv code for a sky + remote control to control the volume on an Olive NAC52? Would save me a lot of remote swapping if there is one!
Cheers, Phil
Posted on: 17 August 2011 by Richard Dane
Phil,
is yours an RC5 NAC52?  If so, most RC5 (philips, Marantz, Arcam etc..) codes should work.  However, there was was an issue where Sky used  at least one of the RC5 codes for some function on the Sky boxes.  Not sure whether they have changed that so beware...
Posted on: 19 August 2011 by Phil Cork
Thanks Richard,
I'm not sure whether my 52 is or isn't RC5, i'll have a play and see how I get on.
Phil
Posted on: 19 August 2011 by BigH47
You need a code like the various 3 or 4 digit to programme the Sky remote.
A code for NAIM amps is 0297.
