| Smartport Role | Description |
| Desktop | Suitable for access devices, such as desktop computers and printers. Implementation increases security on your network ports. This role is not suitable for routers and switches. |
| Cisco Switch | Configures the port in Trunk mode with the other connected device that is expected to be a switch. |
| Cisco Router | Configures settings that are compatible with a network router. |
| Cisco Phone + Desktop | Compatible with Cisco IP phones. Because phones have built-in switches to support a desktop connection and the IP phones typically operate on different VLANs and have QoS configured, these ports have special configuration requirements. |
| Cisco Access Point | If you are using Cisco IOS 12.2 or later, this role can be used for access points that you may have on your network. |
| None | Removes all custom settings from the port. |
Catalyst 2960 config
Posted by: MangoMonkey on 04 June 2017
Spent some time configuring the cisco switch - after some trial and error found this information that I was looking for:
This is useful in case you need to run a cable from the cisco switch into a netgear switch:
From http://www.dummies.com/program...n-using-web-console/
