Qnap Hs251
Posted by: rupbuck on 05 June 2017
I recently upgraded the firmware on my Qnap Hs251 NAS to ver 4.3.3. And now my Naim Uniti Qute2  can't see the UPnP media files. And get the 'source Err. unable to browse'  notice on my Qute.
Not sure if the firmware upgrade is the cause or just coincidence.  Does anyone have any suggestions?
Posted on: 05 June 2017 by ChrisSU
Your Qute is probably just confused and is still looking for the old version at the same IP address. For starters, I would try clearing the UPnP cache via the Naim app, then restart everything.
Posted on: 05 June 2017 by rupbuck
Thank Chrissu. Not sure how to 'clear UPnP Cache via the Naim app'
Settings > Input Settings > UPnP > Clear UPnP Cache.
I can't guarantee that this will solve it, but trying will do no harm.
Posted on: 05 June 2017 by Adam Zielinski
I know this message - you need to select your UPnP server as a source not the QNAP as such. This is the first screen under the UPnP button (normally PC on your remote).
What software are you using on your QNAP?
Posted on: 06 June 2017 by rupbuck
hi , i have tried this , but isn't an option
Posted on: 06 June 2017 by hungryhalibut
Is your upnp server on the Qnap running?
Posted on: 06 June 2017 by Adam Zielinski
rupbuck posted:
I don't understand this comment. Could you please elaborate?
