Speaker cable length
Posted by: Timmo1341 on 09 June 2017
I've spent the last week trawling the internet (particularly this forum) but haven't been able to find a definitive answer to my question, which is:
What will be the detrimental impact, if any, of using speaker cables of different lengths in my new system?
The specifics are: 272, 555PS, 250DR, ProAc K6s. Speaker cable at present is Chord Epic Twin, 2 x 5 metre lengths. It is soon to be replaced by Chord Epic Reference. This is not a cost issue - quite prepared to shell out for 10 metres of the new cable.
However, at present the Epic Twin runs under a suspended wooden floor, in 20mm plastic conduit. Because my left hand speaker stands directly in front of the boxes, the surplus 3 metres is coiled loosely and hidden behind the rack. The new cable will not run through the existing conduit, which will be replaced by 40mm waste pipe with nice, gently swept bends for ease of pull through. Now I could, if necessary, have my son who will be burrowing around under the floor, construct 2 runs of equal length, and 'lose' the surplus 3 metres under the floor. However, if I can simply use 2 metres of Reference on the left hand speaker, and 5 metres on the right I'll avoid the time, effort and additional expense incurred, plus best part of £500 on the extra cabling.
I know conventional wisdom has always been to use identical lengths, and I've read all about the bad old days of using NACA5 as part and parcel of the actual amplification setup, but am I right in thinking things may have moved on a little? Would using unequal lengths risk damaging, in any way, any of my equipment? I suspect not. If indeed the answer is no, would there be any discernible detrimental effect upon the sound reaching my old lugs? If yes, could any members explain, in laymen terms, exactly why this should be, and describe in detail what I will, or will not, hear?
Ultimately I won't risk spoiling the ship etc..., but only if there's a good, scientific reason!
Tim
Posted on: 09 June 2017 by Klout10
To be honest, I don't think unequal lengths could damage your equipment.
However, if you want to have some 'easy of mind', I would stick with two equal lenghts. Otherwise, every now and then you'd ask yourself the question: "What if ..."
Posted on: 09 June 2017 by hafler3o
Put one speaker (5-2=) 3m further away than the other. Then all the differences even out.
Posted on: 09 June 2017 by Darke Bear
Unequal lengths will not cause damage - they will just sound different.
Longer lengths have a lower bass articulation frequency and sound smoother - and short lengths sound faster and brighter.
For good image you want them the same length.
You need to hear it a few times to believe it, so I'm not going to give an explanation - it is there but really not worthwhile, it is easy to hear.
I prefer longer cable lengths, with NAC A5: 4m too fast/busy, 5m reasonable, 6m far better, 8m even better - longer lengths gave better control and more confident effortless relaxed sound.
I eventually when for 7m SL leads and they work fine - longer wound be better but was not worth the expense when you are running Active!
These are just how I hear it and for consideration - I've always suggested people experiment and form their own opinion.
DB.
Posted on: 10 June 2017 by Huge
There may be subtle differences in the sound on each channel.
However there may be a different problem with 2m, depending on the tweeters in the speakers.  If these present a capacitative load, 2m may not give enough inductance to stabilise the poweramp: This is why Naim specify a minimum of 3.5m of NAC A5 (which gives 3.5μH of inductance).
I can't tell you if this is going to be a problem as I don't know the precise stability limits of a NAP250DR, or the electrical equivalent circuit of your speakers, or the electrical characteristics of the Chord speaker cables.
Posted on: 10 June 2017 by Timmo1341
Thanks those who have taken the time to reply.
I think on balance I'll go with equal 5m lengths, particularly as if I ever decide to switch to another cable the trade in value of 2 x 5m will be much greater than uneven lengths.
I would still be interested in reading a plausible explanation as to why the sound heard by the listener would be different. I know it's not exactly comparing like with like, but years ago when I had a Teac Reference 500 AV system feeding Kef KHT 2005 eggs and sub woofer, all the cables were of different lengths, and I was never aware of any difference in the quality or 'type' of sound - perhaps you sometimes only become aware of what you are listening for when it's pointed out to you? Perhaps ignorance truly is bliss sometimes!
If one assumes that speaker cables have an effect on the sound of a system, this must be caused by one or more of the physical (mechanical or electrical) properties of that cable.  Therefore a 5m cable will exert 2.5 times the modifying influence that a 2m cable will exert, no matter what form the influence takes.
N.B. this does not show that the resultant effect of that influence will appear to be 2.5 times as great, just that the influence itself is 2.5 times as strong.
Posted on: 10 June 2017 by ryder.
I had just written to Chord just recently on this with my intention to use 4m on one side and 5m on the other side. Nigel responded by saying that although it will likely work out fine, they couldn't recommend it as Naim amps are rather sensitive and equal length cables would be the best.
Posted on: 10 June 2017 by David Hendon
The cable presents a capacitive and inductive load which is dependant on length. The amplifier could be designed to ignore these but Naim amps have always regarded the speaker cable as part of the amplifier. I believe the newer amps are less sensitive, but the NAP 250 has its roots way back, so personally I would use equal lengths.
you should not coil the spare because that adds further inductance. The Naim advice is to make the spare cable into a zigzag and tape it on the middle. This way the inductance added by each zig is cancelled by the next zag.
best
