Big Brown assures me that my new NAP 300DR will be delivered within 48 hours, which is great news. I will, however, then have to make a decision on how to rack the two new units, as space is very tight.
I have a bespoke custom made rack built from heavy duty solid cherry, as well as a 4-bin (2 over 2) cherry LP storage unit which holds approximately 200 LPs next to that.
I have neither the interest nor the funds to change the current racking situation in the near term, although long term plans do call for upgrading to a twin Fraim rack down the road.
My choices for locating the 300DR are:
1. Both units on the bottom shelf of the main rack in place of the NAP 200, one box on top of the other.
2. Move my nDAC to the top of the LP storage, where my Magnum Dynalab FM tuner will have to live on top of it, and place the amp in the nDAC's spot, with the 300 power supply where my current NAP 200 is.
3. Site the 300 amp unit on top of the LP storage, leaving the nDAC where it is in the main rack, and again site the power supply where the current 200 is. Again my Magnum Dynalab FM tuner will have to live on top of the 300 amp.
The question is which solution is likely to result in the best sound quality? Swapping the units around to experiment is not really in the cards (extremely bad back).
About 80% of my listening is digital going thru the nDAC (UnitiServe, NAS, and Tidal via ND5XS, and a little via a CD5 XS), 15% is analog via my turntable, and 5% FM radio. The FM tuner is usually turned off via the power switch although I could unplug it easily from the mains when not in use for a truly "dead stick."
By the end of the summer I will have a secondary two-shelf rack for the top of the LP storage unit, which will make things much easier. But what to do in the meantime?
Posted on: 13 June 2017 by Tallan
Probably, yes, and they are both powered items. The reason for mentioning a good rack is that Naim boxes tend to sound best on light but rigid racks, which are designed to transmit vibration. Heavy solid wood racks don't do this. You mention Fraim, so I'm sure this isn't news to you.
No doubt. But surely you'll agree, HH, that there's more than one way to skin a cat.
As I understand it the goals for an audio rack are to provide a secure and convenient environment for your gear: good ventilation, easy access, and of course most would say it has to look good as well. What isn't welcome are microphonic or resonant surfaces which can transfer unwanted vibration to the audio components. The rack exists in a noisy, often loud - but hopefully musical - environment, after all.
As with turntables there are at least two ways of tackling the problem: dissipate the vibrations or resist them. From what I can tell Fraim racks (like the high end Rega turntables) are designed to channel unwanted vibrations away from the sensitive areas where they are dissipated in a controlled manner that doesn't audibly impact the equipment.
Thus the Rega RP 8 and 10 are very light weight and rigid, designed to channel vibration away from the tonearm and platter surface. More popular at the higher end of the turntable market, however, and employed almost uniformly at the extreme high end, is the use of mass to damp out the effects of vibration. The six figure Continuum Caliburn, for example, weighs in at 160 pounds, without it's accessory stand.
My point is that without a side by side comparison it's hard to say for sure which is the sonically better rack, what I have now which is based on damping mass but also features shelves which are isolated from the outer frame, or the rigid, lightweight, dissipating Fraim.
Because I believe in the synergy Naim brings to the table, as well as the efforts they make in research, I'm well convinced that for their equipment the Fraim solution will sound best, but at the same time I don't believe any other design or product has to be a failure or a dud by comparison.
Hopefully I haven't just hijacked my own thread!
WAY too many boxes, which is one reason new racks are a back-burner item. My plan is to trade the whole digital side of my system (UnitiServe + PS, nDAC + PS, ND5 XS + PS - six freaking boxes!) for an NDS + 555PS as soon as I can afford it.
In my own defense when I started building out my main Naim system I was an analog and CD guy, and only over the past 2 or 3 years has my listening source morphed from that to being mostly hi rez digital, which is itself not inexpensive to acquire.
Posted on: 14 June 2017 by yeti42
If you put the 300ps on the LP rack and the head unit where the 200 was does the Burndy(s?) clear the floor and where is the pre in relation to the 300ps.
My 500ps next to and half a shelf above the 552 with a 555ps below the 500ps robbed the system of its boogie, Raising the 552 a shelf restored it.
Burndys shouldn't touch the floor.
Posted on: 14 June 2017 by Sten
I recently took delivery of my very own 300DR and racking was a bit perplexing so I am glad of this thread and any advice that can be extended
I have Fraim Lite with 2 base levels and the 300 and 300 PS are side by side and inevitably the burndys are laying on the floor along with many other cables........the current stacking order is:
........................282
TT....................ND5XS
SL.....................SC with HC & NAPSC on top (temporary)
300PS..............300
3 standard shelves on left and 3 standard + 1 tall shelf on the right.
The SC with 282 and the HC with SL - I preferred this to the other way around.
Having read this thread I should probably look at swapping the 300 and 300PS. However, with the SC and 300 on different stacks the supplied left and right channel cables only reach if the SC is to the right of the 300.....so I might try
............................282
TT........................ND5XS
SL........................300PS
300......................SC with HC & NAPSC on top (temporary)
Does that make sense?
Having said all that I am extremely happy with the 300 (in any orientation) but tinkering is kinda part of the joy right.....
Posted on: 29 July 2017 by rightcoastants
Also about to take possession of a pre-loved 300DR this week and have a racking/space issue. Currently using a 3 shelf Isoblue but will soon have 4 boxes (272, XPS-DR and the 300DR to replace the 250DR). Not really in a position at this time to purchase another audio stand, so was thinking of the either stacking two components on the top shelf of the Isoblue or possibly move the 272 or other components onto the top of a sideboard/credenza unit. I might also be able to get a Target Audio type stand to place the power supplies. Will also be using longer lengths of NAC A5 which will now allow my to move the kit off to one side. The sideboard can likely accommodate 3 components side by side by side.
If I used the Isoblue 3 shelf solution, what about the XPS + 300 PS on the top shelf, 272 middle and 300 bottom?
Suggestions ?
