Connecting Nap 250 to nac 272
Posted by: Sharon Kabir on 13 June 2017
Hi
I'm going to purchase NAP250DR+NAC272. Is the cable connecting them included in the package or should I purchase a cable separately?
If so . So what cable I need?
THANKS
SHARON
Posted on: 13 June 2017 by Finkfan
Morning Sharon. The din to xlr cable is included with the 250DR. The xlr end will go into the 250 and the din end wil go to one of the analogue out sockets on the 272, I use the one on the right as you look at the back of the 272.
Posted on: 13 June 2017 by Adam Zielinski
PDF manual on NAIM's website is your friend.
Posted on: 14 June 2017 by ChrisSU
The cable is always included with the power amp, as different ones use different cables and this ensures that you get the right one. With new gear you don't need to worry about it, but if buying used, you should check that the seller will provide them.
Posted on: 14 June 2017 by Richieroo
The std din to xlr is pretty good........... I tried Super Lum version ... it made a difference but not enough.... the Which-hat is good if you need one.
Posted on: 14 June 2017 by Finkfan
I have a witch hat 4x din to xlr. Swapped back to the standard naim cable this evening and which sounds much better between bare 272 and 250DR. 4x sounded better between SN/HCDR and 250DR. Will re assess the 4x once an XPSDR is in situ.
