NDS installation advice
Posted by: Richieroo on 15 June 2017
Hi I have just got my NDS (yipee!)...... and I will be installing soon. I propose to connect it to my 555ps. I notice that the burndies are marked with white stripes from the factory.... one has 2 and the other 1. Using logic does this apply to 'socket 1 and socket 2' as sockets are illustrated on the rear in the manual? Also at which end are stripes to go  ..... near the NDS or near the 555ps..... can anyone advise (ie are they directional).
Posted on: 15 June 2017 by Harry
You'll want input 2 connected to output 2 with two stripes at the NDS end.  Input 1 connected to output 1 with the single stripe at the NDS end.
See here: https://www.naimaudio.com/site...glish%20Iss%202A.pdf
Posted on: 15 June 2017 by Adam Zielinski
Reading a manual will provide all the answers - stripy side goes to the NDS.
Posted on: 15 June 2017 by Richieroo
Cheers...
Posted on: 15 June 2017 by musicfan51
You'll love it!
Posted on: 16 June 2017 by Richieroo
I did check through the sparse installation guide .... nothing was mentioned about burndies.....
Hi I have looked at the link ..........this has it in clearly....hmm my destructions don't ... cheers
Posted on: 16 June 2017 by Adam Zielinski
Page 3 of that PDF has the answer...
Yep got it ....... it just that my original ones did not...fnx
How does the NDS sound?
Posted on: 16 June 2017 by Harry
Fantastic.
