VOVOX speaker cables
Posted by: spacey on 17 June 2017
Any VOVOX user on here?
Just changed the TQBs I have/had and am currently demoing some VOVOX Vocalis (3.m pair )speaker cables... so far really impressed.
Hi Spacey,
I have these, too. Admittedly my Texturas were already in place before I bought my first Naim electronics. Good to see another happy owner.
Yes very impressive, much better than the Tellurium Q Blacks, literally in every way.
Did you ever try Texturas against Vocalis speaker cables?
The Vocalis range wasn't yet available when I bought my cables. It was only Initio and Textura back then. As my local dealer no longer has Vovox in stock, I never had the chance to listen to the Vocalis and compare it to the Textura.
Given the popularity of Tellurium Q around here, I was wondering if I should try them out. After reading your impressions, I will listen to some more music instead
Mulberry posted:
I wouldn't care much about conclusions based from rapidly box or cable shifters/promoters
IMO and IME, one need more than a day or two to make final statements on such stuff
Definitely don't change the Texturas..., really liking what VOVOX are 'not doing' if you get what I mean.
I am going to be trying out another set of cables against the Vocalis, which are EWA LS-25s before I make my final decision. They are the ones designed by the person who invented the company Terullium Q but has recently gone on his own. The LS-25's are effectively the same the TQ's Ultra Blacks. Will be an interesting demo
Hi Spacey,
while I have noticed your preference for the HiDiamond cable, try to get some Vovox interconnects to go with the speaker cables. I think the is a clear synergy between these two, even with RCA instead of DIN plugs. There is always the custom termination option...
But, as always, go with your own impressions.
I've moved on from the vovox and HiDiamond 3s - am now using EWA LS-25s.
I don't have any interconnects just Ethernet from the NAS and Optical from the TV into the SU.
Issue I found with the VOXOX after having them in for 2-3 weeks was the 'hardening' of the sound and a single monotone-ish bass.
