Uniti Core rips v Mac rips
Posted by: Paulie on 19 June 2017
Hello --
Looking forward to taking delivery of a Uniti Core to use as playback/storage/ripping for my music collection, rather than a MacBook Pro (which I've used for the last several years).
Question: From an audio perspective, am I better to re-rip my CD collection using the Core OR will the files I've already ripped (in combinations of AIFF, Apple Lossless and AAC mostly) be sufficient if I just move them from my MacBook onto the disc on the Core?
Also, can I move DSD files onto the Core and have them playback in their native form? I'm using a DAC-V1, into a SuperNait2.
Thanks.
Posted on: 19 June 2017 by ChrisSU
The lossless files will probably be fine, I would have a listen to a few just to satisfy yourself that they as good, as you may find a subtle difference between them and a Core rip. I think I'm right in saying that the Core cannot transcode to WAV on the fly (i.e.during playback) which some prefer to do so you might consider converting files to WAV. I would suggest plenty of trial and error with this before you load all your music onto the Core.
For the AAC stuff, definitely re-rip if you still have the CDs.
Posted on: 19 June 2017 by Adam Zielinski
If AIFF etc play fine I would not re-rip them. Although I found that my iMac occasionally produced faulty rips.
Posted on: 19 June 2017 by Paulie
Thanks Adam and Chrissu -- much appreciated.
Chrissu - RE the AAC files.... some of them are purchased off iTunes.... and iTunes will still be a source for some purchased music.... Assuming there's no actual technical issue with the Core playing those files?
Apologies for the newbie level question..... I couldn't find an answer with a quick search. Thanks.
Yes, you can play AACs. You can also allow the Core to access your iTunes music folder rather than transferring it to the Core storage if you want to.
Posted on: 19 June 2017 by David Hendon
As Chris says, the Core can't transcode on the fly at the moment. Where it is on Naim's to do list is unknown....
best
