More Mu-so streaming woes via TiDAL
Posted by: Tommy Gander on 20 June 2017
Add an album as favourite. Play said album. After playing track the option to play another track disappears. Just nothing. Useless. Just so unhappy. Closing the app is the only solution, then it happens again.
Posted on: 20 June 2017 by Tommy Gander
Just to elaborate: select album, play track... all options still in place. As soon as track finishes. Nothing. Bar at the the bottom disappears. Clicking on other options doesn't work.
Posted on: 20 June 2017 by Finkfan
Does it just play one track of the selected album?
Hallo. No the rest of the album plays but there is no option to select another track or album. The bar at the bottom disappears until i close and restart the app.
Are you using the naim app? Or the Tidal app and sending it to the Muso?
Hallo. I'm using the NAIM app on my iPad and selecting TiDAL. The bar at the bottom of the screen has disappeared. All the albums and tracks that i have favourited are visible.
Strange. I can't get my app to do that. Have you tried resetting the app in the settings menu?
Posted on: 20 June 2017 by Simon_H
Although not strictly related, I use Audirvana + on my Mac Mini and according to the developer there are currently issues with Tidal via 3rd party apps at the Tidal Server end which may also be impacting the Naim App as well.  On Audirvana the behaviour is for the first ~15 Album to load but then you just get a dotted outline of an album and the message "Loading", I also have issues accessing My Music tracks.  I don't have the same issues using the desktop client, the Naim client may present the same issue in a different manner.
Posted on: 21 June 2017 by Tommy Gander
Hallo Playmates. Just to update you, as it would be rude not to. The problem has been resolved, although I don't know how. I reset the app but that didn't make any difference. I then reset the Mu-so itself as I was having to add it manually as the app couldn't find the room. At this point, I should add that I have a network cable going straight into my Mu-so via my router (as recommended by the boffins here). I disconnected the network cable and then tried to add it to my wi-fi network without any joy! In the end I just put the network cable back in and hey-presto all was OK with the app and the room was found straight away. The bar which indicates which track is playing at the bottom now stays visible. Thanks to all who responded.
Posted on: 21 June 2017 by Finkfan
Glad to hear all is well again Tommy.
