BNC sockets
Posted by: Sister Ray on 22 June 2017
Does anyone know the diameter of the cutout used by Naim to mount their BNC sockets?
Posted on: 22 June 2017 by Richard Dane
Ray, an email to Naim will probably get an accurate answer.
Posted on: 22 June 2017 by james n
Ray - if you get no luck with Naim then it should be 9.7mm. Best to use a dedicated hole punch if you can to get the anti rotation flat spot in the hole.
Posted on: 22 June 2017 by Sister Ray
Thanks forthe replies.
