Shuffle/Repeat Missing from Naim App version 5.6 display on iPhone
Posted by: juanito on 24 June 2017
The shuffle/repeat buttons are missing from the Naim App version 5.6 display on an iPhone 5S - presumably because the display is too narrow - on an iPad, the shuffle/repeat buttons appear to the left of the previous track button.
Steps to reproduce - start playing UPnP playlist, then try to activate shuffle or repeat.
Posted on: 24 June 2017 by Klout10
Depending on your view you have three dots in the top right corner ...
Posted on: 24 June 2017 by juanito
That used to be the case, but pressing the "three dots" button no longer brings up the shuffle/repeat buttons.
Posted on: 24 June 2017 by hungryhalibut
It works fine on my iPhone SE. You need to access it from the now playing screen that has the tracks listed vertically, not the one with the large cover art.
Ah - I see it now - sorry for the noise
Posted on: 25 June 2017 by hungryhalibut
That's the trouble with being older - these things seem to be intuitive to twenty year olds. You may be twenty of course, which would blow that excuse out of the water.
Posted on: 09 July 2017 by Paulie
Ok. I've clearly missed something. I've (I thought) followed your instructions above. I cannot find a shuffle feature. Simply put: I'd like to be able to open the app, press shuffle and have the Core randomly shuffle through all of the tracks on the unit. Is is possible? I haven't been able to figure it out.
Thanks.
