one speaker is veeeery quiet - tested everything I can think of!
Posted by: Hoolio on 25 June 2017
I have a problem where the sound out of the left speaker is almost non-existent - when I swing the balance hard to the left it sounds like the 'shadow' of the right speaker channel...but it's only when I am using the DAC as the source.
Amps: Olive series 102 to 180
Speakers: SBLs
DAC: Beresford Caiman MkII (about 6 months old) with Chromecast input
Testing to try and identify the issue and assumptions as below:
1 - DAC onto each input on the 102, same issue on all inputs - conclusion: it's all or none of the inputs at fault
2 - Mini-jack to Din cable to test each input - both speakers working at full volume - conclusion: it's not the inputs, and the amps appear to be OK too as they are sending perfect stereo music to both speakers with this setup.
3 - Swapped speaker cables over out of the 180 - now the right speaker is the quiet one - conclusion: the signal isn't exiting the 180 to the left speaker
4 - Used NAD amp in place of the Naim amps streaming through the DAC with an RCA to RCA lead to this amp- all working perfectly - conclusion: The problem is either the RCA to Din lead I use from the DAC to my 102, or my Naim amps are at fault. Also confirms the speakers are fine, and that the DAC is fine.
5 - Used DAC and Chroemcast to stream to my other stereo (cheap NAD amp and Mission speakers, RCA to RCA cable from DAC to amp) - all works perfectly - conclusion: DAC and Chromecast are definitely not the issue. Maybe it's the RCA to DIN cable from DAC to Naim amp?
6 - Bought a new RCA to DIN cable - problem remains. dammit! maybe this cable is stuffed as well? it was a cheap one - USD$30 on Ebay. switching red and black RCA out of the DAC it stays quiet in the left speaker - conclusion: confused! Does this mean the cable is OK, as the problem is identical at the speaker end when swapping them over?
6 - use Coaxial input to the DAC to remove Chromecast from the equation, same quiet in left issue.
7 - got the boxes out to package the amps up to take to a repair place, and had a read of the manual...didn't realise the connector lead from 102 to 180 is directional...and it was the wrong way around! swapped it, and on the night though that had 'fixed it...but a week later it's back to being quiet in the left speaker again...only from the DAC sources
So, I feel like I've ruled out it's the amps, speakers or speaker cables...but I've also ruled out it being the DAC or Chromecast in at least one test above....and does swapping red and black RCAs out of the DAC and still having a quiet left channel mean both red and black RCA connectors are working fine?
HELP! :-)
