Speaker Placement Question and Ideas....
Posted by: Arnsider on 27 June 2017
Has anyone had any success, and is it even a good idea, placing their speakers either side of the TV across a room corner? I ask as my room, although reasonable in size (26ft x 14ft), is somewhat limited in placement and I was considering an experiment.
If I explain, there are only two realistic options of placement in my room. The first is either side of a mid positioned fireplace along the long room wall similar to HH's original system pic... This has the advantage that the speakers are open, about 8 inches from the back wall and spaced correctly. The disadvantage is that I cannot sit facing their midpoint as this fires at the room doorway.
The second option is they fire down the long length of the room which works apart from again my furniture does not face them and a sofa has to be in the way. It's not feasible to have any other placement as the TV is in the opposite corner to the above second position.
Just wondered if anyone has had any experience trying this before I do all the humping around to try... Speakers are Kudos X2's.
Cheers all...J
