Hum with Rega RP 10 an Superline/Hicap
Posted by: ChrisBerlin on 03 July 2017
Hello,
I've just installed my new Rega RP 10 and a Naim Superline powered by a Hicap. The cartrige is a Koetsu Black. The preamp is a NAC 272, so there is no possibility to power the Superline without a separate PS. Now I hear a hum - I think at about 50 Hz - over the loudspeakers - especially over the left channel. The reason for the hum may be a wrong grounding. Because there is no separate grounding cable from the rega, the grounding port of the Superline is not used. I tried to avoid the hum using a separate grounding cable from
- tonearm chassis to grounding port of the Superline
- grounding port to the NAC 272 chassis
- outer contact of the cinch cable from the RP 10 (left an right channel) to the Superline's grounding port
In every case the hum becomes louder. Grounding the right channel involves an additional hum on the right channel of the speakers.
The Superline and the NAC 272 are powered over the same plugbar - the HMS Energia 3/1. The Rega is powered over a Musicline Plugbar which is directly connected with the HMS Energia.
Before installing the Superline I have used a Lehmann Back Cube SE phono preamp. There were no problems with hum at all.
Thanks for help, answers and hints to avoid the hum...
