How can the app N Serve be reset after substantial changes in DOWNLOADS folder?
No doubt others experienced this - deleting several albums put in DOWNLOADS, going back to N Serve and the 'present albums' needed to be updated.
i tried deleting the app then reinstalling but the old albums are still there and it's messy finding music.
Can anyone relate and offer advice?
Posted on: 12 July 2017 by David Hendon
Yes as HH says. I don't think there is any way to force this from the n-serve app. Occasionally I found that shutting down the US and then restarting it would sort it out, but the only reliable way is from the Windows Desk Top Client, which personally I find to be a monumentally unfriendly and obscure programme.
A main reason I bought a Core was so that I could forget forever about the Naim Windows DTC.
best
Posted on: 12 July 2017 by Klout10
I understand your comments HH, but I also used to own a HDX (which is basically a US with analogue outputs) and for me it's a great machine. I'm not into the networking/ computer stuff and by using my HDX I didn't need to worry about correct ripping settings, network issues etc. just ripping your CD collection and enjoying it ... it comes at a price though
Posted on: 12 July 2017 by ChrisSU
If you're a Mac user, do the rescan using N-Serve for Mac, it's very quick and easy. If you don't, changes can sometimes take days or even weeks to show up.
