Supernait2 Hugo/Hugo2/HugoTT
Posted by: ThatsNotMyNaim on 12 July 2017
Hi all,
I managed to borrow a Hugo2 and TT to compare at home. I used a SN2 and also a Sugden A21 as amp.
System
InnuOS Zenith (PL), stock USB cable with AQ adapter for micro connector, DAC, Chord Shawline RCA, SN2/SugdenA21 (PL), Epic Twin spk/Sig Links, ProAc 118 (Plus DB3 on loan)
Roomed is controlled well. Decent heavy/filled stands and racking.
I'm not really into double Dutch about tech specs and noise levels, so i'll say it how my emotional and musical ears hear it:
All work very nicely with the Supernait2/A21/ProAc.
I caveat my thoughts with the fact that there maybe other system factors that cause or contribute to certain percieved effects. I used the same USB for all. Before switching back to my preferred 15cm stock cable after.
PS - expensive USB cables. Forget them. Keep it short and basic IME.
Hugo
Still sounds good. I think some will avoid the outlay for Hugo2 and not see it as essential. Others will say it's a must upgrade. It's definitely flatter sounding vs the bugger brothers. Much less air. Smeared/blurred compared to Hugo2 but some might prefer this. It sounds more upfront also maybe because of less feeling of space. Still enjoyable but I have always felt it sounds digital - I crave that analogue sound. People say Hugo is analogue - yes compared to most other DACs out there but it still doesn't capture that true analogue emotion for me. Never has, always feel a bit cold and thin. But I have enjoyed it still for the price. Maybe I should just buy vinyl!
Hugo2
Much more 'air'. Much more dimension. More music. More realism. Everything sounds more lifelike by a good degree.
It's spacious, engrossing and haunting. With a real musical flair and drive. It's the purest and most entertaining of the three. The air of the stage goes high and wide with real panache. It's exciting and has a realistic flair and energy. Harmonics are scary good. Digital edge is stripped much further back vs Hugo1. This is soooooo close to that truly fluid analogue emotion. Where everything fits and works and is believable without questioning. In my opinion this is still however ever-so-slightly slightly short of purist analogue heaven. It's detail, space and cohesion of the music are quite uncanny but I still hear a slight wince of digitalness/hardness. Improved but not gone - maybe system related?
HugoTT
At first I was listening to this thinking; "This is beautiful. Smooth, organic and more analogue...". It's "better". However after a few days flicking back and forward I have found the TT to be flatter, less inspiring and ultimately 'less musical and less realistic' than the Hugo 2. Yes, the TT is the wiser, MUCH more solid and controlles, smoother, more mature and probably more specy model but when you go back to the Hugo2 you hear the music more 'truly' and more 'believable'. More realsitic pace and energy in the Hugo2. The TT supresses/tempers/flattens the music I my opinion with it's smoothing and lacks air and flair vs Hugo2..However, there is a BIG trade-off. You loose a certain solidity, control and fullness of feel that the TT has that is very desirable. The Hugo2 sounds a bit more brittle and thinner than the TT. More gristle. Maybe just exposing the recordings more. I have tested many tracks though.
Conclusion
Hugo2/TT > Hugo
I'd be hard pressed to imagine anyone could deny that the Hugo2 doesn't do 'music' with more realism, pace, space, flair and evergy than the TT. If I were aiming for analogue then the Hugo2 goes further with some downfalls.
Likewise I would imagine most will clearly be able hear the solidity and control of the TT which makes it quick appealing/convincing.
For me you can hear the effects of new technology in the Hugo2 that take it to a more enjoyable and natural place than the TT despite it's slightly more brittle nature.
My view
Wait for the TT2 (or maybe Naim will get moving on DACs). This new TT2 could be absolutely magical in my opinion if it forges a balance of the the H2 and the TT. It might just be the unicorn!
If you have the money though right now and want to upgrade. My choice would be the Hugo2.
The TT sounds great. But sounds like old technology when you hear the energy, sparkle, dimension and realism of the Hugo2. A fuller and slightly smoother Hugo2 will be absolute heaven. I'd be surprised if Chord haven't realised that the next TT2 could be another huge breakthrough.
Digital is getting more realsitic. But still a way to go I think. Just my two pence worth.
