Is merging albums possible.
Posted by: ngene on 14 July 2017
I have had done a search on this. And some people were complaining that you cant merge albums. As i didn't see a fix for it in the thread i take that albums with 2 or more CDs cant be merge. They need to add a function so we can merge albums.
Posted on: 14 July 2017 by hungryhalibut
I'm not sure who 'they' is and on what you are trying to merge albums, but using dbpoweramp you can do whatever you like regarding merging and splitting, renaming or whatever.
Posted on: 14 July 2017 by ngene
I want to merge double albums into one. You have to pay for dbpoweramp and i have paid enough as it is with Naim. Merging albums as some other users here have said it should be in the DAC Software.
Posted on: 14 July 2017 by David Hendon
Merging albums within the DAC software.......
Posted on: 14 July 2017 by jonnaim
Ngene
dbpoweramp is about £20 if you can afford naim hifi kit you can afford it.
its like a Ferrari owner moaning about the price of petrol.
makes you look ridiculous
Posted on: 14 July 2017 by Simon-in-Suffolk
I agree with Nigel - really straightforward to merge albums - just ensure you give the tracks the same album name and give an appropriate track sequence number
I tend to do this on multi CD compilation albums. Little cheap tools like dbpoweramp makes this child's play if you don't want to manually edit meta data using windows explorer etc - which is not much more than child's  play
Posted on: 14 July 2017 by SamS
Mp3Tag will do this for free although a donation would be nice.
Posted on: 14 July 2017 by Mike-B
SamS posted:
Load disc-1 on the app followed by disc-2 & tell it to play last.  Thats for free as well.
Posted on: 14 July 2017 by ChrisSU
ngene posted:
DACs just process the data that's fed to them. The metadata that gives you album listings, etc. is stored in the music folder, and is there before it is played via a DAC. Then, if you're using a streamer, this info is displayed by the control point. You haven't said what (Naim) equipment you're using, but it sounds like what you need is a metadata editing app of some sort.
Posted on: 14 July 2017 by Adam Zielinski
You can also use Metadatics for that - re-assign new metadata to both albums, or ideally using 'disc 1 out 2 and 2 out 2' function.
