ios app update
Posted by: jon h on 15 July 2017
just had 5.7.1 arrive on my iphone -- cant test it till later this week, am 5000 miles away from my core
Posted on: 15 July 2017 by jon h
i have fired it up -- it hangs on "finding rooms" for a minute or two. I guess the "am i on the network on which I last saw that naim box" code is still unwritten.
As far as I can see, all the UI issues are still there. The confusion of "set up a new product" versus "add new room". The wrong vertical alignment of muso icon versus QB.  I cant go any further till there is a box for it to find.
And the "which model are you setting up?" in the fade-out zone (on iphone 7plus)
Posted on: 15 July 2017 by Dr_J
Almost hesitate to post this, but moved from 5.7 beta to 5.7.1 from App Store, IOS 10.3.2 on both iPhone 7 and iPad Air and all appears normal function to 272 and Qute2 through Apple Time Capsule and Airport Express WiFi, streaming from Synology DS414slim with both Synology and Minimserver streamers and Mac Mini running Firestream.
Perhaps it's just luck......
KR, J
Your comments don't invalidate mine.
Posted on: 15 July 2017 by GregU
With the new version I counted
To open the naim app, and play something on spotify, I have to click 10 different things to play      Brilliant!!
