Coffee
Posted by: Simon-in-Suffolk on 16 July 2017
i know there are several dedicated coffee web sites out there - but I thought would be interested to compare notes with those more musically inclined. For most of my life until now I have not really liked coffee - but I now have discovered i really do rather like coffee after all - but it has to be made and prepared properly - and that appears to exclude the vast majority of hight street chain coffee shops, and roasted beans from supermarkets
So I have got to talk to some local independent baristas and roasters, bought a burr grinder and manual espresso machine and practised practised practised.. and I am now getting there such that I can enjoy and savour the complex tastes of an expresso shot almost like a whisky or cognac... though with me with slightly less predictability at the moment until my skills progress . and yes I will probably need to invest in some water proof .1g scales - a local independent barista said I probably need that if I want true consistency.
For any coffee heads out there - what is your current bean and roaster of the moment and favourite preparation?
I am really enjoying a locally (Firestation Roasters @Woodbridge) lightly roasted DR Congo Latumba Blue Mountain bean that some some lovely tastes of fruit/oranges with a gorgeous fruity bitter crema. I using an espresso preparation and and grinding the bean so I am extracting for around 25 seconds with a 5 second pre-infusion at around 9 bar @93 c for a single shot.
I have been enjoying Butterworth & Son (@Bury St Edmunds) 100% Espresso blend with a similar preparation but doesn't quite have the fruitiness and light notes of the Congo bean...
I am enjoying espressos, long-blacks and flat-whites... although the milk in the flat-whites doesn't go so well perhaps with the fruitier beans.. Also the beans seem optimum for extraction between a week to four weeks after roasting.
So any other interesting coffee beans and preparations to try?
Posted on: 16 July 2017 by Huge
You have seriously good taste in coffee!
As an everyday coffee I quite rate Illey, not in the class you're talking about, but the best I've found from supermarkets. To get anything better requires a significant shopping trip for me, so better coffee is a luxury.
I currently use 35ml @ 95°c, 4s pre-infusion, 15s push.
I agree about the High Street chains - useful for company and rest when out and about with friends or for the caffeine in an emergency, but not useful for much else.
Posted on: 16 July 2017 by tonym
Nick From Suffolk's your boy here. Me, I'm an unsophisticated Nespresso fan, can't be doing with all that fuss.
Of all the 'preset' pod machines, the Nespresso is definitely the best.
Posted on: 16 July 2017 by naim_nymph
The mistake most people make using instant granular coffee is the boiling the living daylights out of it.
I can't drink it the way all my friends make it...
Good preparation technic: With the kettle brought to the boil fill the cup quarter full simply to warm it. Allow the kettle to cool slightly while swilling out the warmed cup, and putting in a heaped spoonful of Kenco Rappor. Pour the slightly cooled down [not boiling!] water in the cup to fill at half full only (or half empty depending upon if you're an optimist or pessimist). Add a good splash of shaken fresh semi-skimmed milk (about a quarter of the cup quantity). Stir and enjoy. If you're wimpy enough to have need of sugar use Demerara.
I know this instant is not proper fancy pants bean coffee but it's a very easy non-faff way of making a quick satisfying cuppa : )
Posted on: 16 July 2017 by Simon-in-Suffolk
Thanks, I guess you can choose your bean etc on the Nespresso machines? - and I think I remember seeing some create their own pods etc? To Tony's point about fuss - once you have a routine - you can prepare a wonderful coffee from bean to cup in about 5 minutes - but there is always a bit of mess admittedly... at least with me
Debs is spot on with temperature - the same holds true for coffee and tea - the temp is crucial and it must not be boiling - and with milk coffees the milk should not exceed 65to 70 c or thereabouts in preparation. If you sip a coffee, a milk coffee or tea and its too hot to drink after preparation then it has almost certainly not been prepared correctly and you have probably killed much of the subtle flavours - and if too cold then almost certainly you have not warmed the cup / pot correctly and again you will be under achieving the taste
Posted on: 16 July 2017 by ssmith
I'd recommend Has Bean as a good place to buy beans from. They do lots of single origin coffee and a good subscription service. The filter methods are generally highly regarded particularly Chemex is good. Would also recommend Aeropress as worth trying.
I would say the most important thing in terms of equipment is a good grinder and selecting right grind size.
Thanks - yes I have discovered the importance of the grinder and the correct grind size - especially with espresso where there is not much room for error. Also discovered that ground beans deteriorate in terms of the subtle tastes really quickly.. so you need to ensure your grounder is efficient here especially for home use. Looking forward to trying some filter and brewing methods to aim to experience the different taste balance of coffees.
Posted on: 16 July 2017 by Cbr600
My coffee is a simple task, use Lavazza beans from tesco, ground with a Krups electric mill, and then a Bodum cafetière.
simple and easy, and a nice flavour
Posted on: 16 July 2017 by Suzy Wong
We've got a Delonghi bean-to-cup maker. Simple to use.....beans go in the top, water in the tank......coffee come out of the spouts.
Waitrose and Wittards are good for whole beans.
Posted on: 16 July 2017 by Eoink
I am currently drinking Kenya AA medium roast, bought as beans from the local Bean Brothers of Huddersfield. Ground in a DELonghi burr grinder. brewed in a filter machine. Lovely blue fruit notes, and a great smell of coffee.
Posted on: 16 July 2017 by pete T15
Hi Simon , I have a brilliant local independent coffee shop (DetourW12) that source their coffee from Electric coffee based in Ealing . I'm led to believe they roast their beans in Sussex ?? As Agent Cooper (Twin Peaks) would say "Damn Fine Coffee" .
https://www.electriccoffee.co.uk
Posted on: 16 July 2017 by Chris G
My recommendation is to use an Aeropress. Make sure you use sufficient coffee - many of the big chains use too little. As mentioned before, don't use boiling water. I often find Taylors of Harrogate produce many excellent blends. I particularly like their Lazy Sunday blend
Posted on: 16 July 2017 by Drewy
How about a jar of mellow birds?
If visiting Salisbury (I can't think why anyone would!), I thoroughly recommend Coffeelab - facing the market square, near Debenhams.
Posted on: 16 July 2017 by Tony2011
Coffee is trial and error until you find something to suit your taste. Nothing wrong with shopping for coffee at your local Sainsbury's (larger shops). That's where I get my Taylor's Cacao Superior Colombia beans. I also get Lavazza's Crema e Aroma beans from Amazon. No need to go to "posh" shops and pay a premium to buy quality coffee.
Posted on: 16 July 2017 by Bruce Woodhouse
Union Coffee Company supply my beans, mail order. I tend to like the lighter roasts and have had some great Rwandan varieties recently from them. They sell a great variety and never had a poor batch. Their blends are not bad either. I discovered the company when a friend bought me an annual 'subscription' gift which meant I got a different pack each month and that was a great way to explore a good range of styles.
Use a Jura bean-to-cup machine. Lovely and stupidly easy to make a good coffee.
Bruce
Posted on: 16 July 2017 by dave marshall
I alternate between the various offerings from Taylors of Harrogate and fresh roasted beans from a local artisan roaster.
All fed into a Jura bean to cup machine, powered, naturally, with a Powerline, for that little extra je ne sais quoi.
Posted on: 16 July 2017 by Romi
When I used to smoke I adored the sensation of having double very sweet expresso with my Malborough cigarette. Now on ocassions I still have double sweet expresso but its not the same without the cigarette......
Posted on: 16 July 2017 by Kevin-W
I like my coffee how I like my cheddar - it should take the roof of your mouth off. I get this amazing stuff from Gama, a Turkish distributor/wholesaler in North London. It comes out like tar and contains enough caffeine to wake the dead. Which is how it should be.
Rather more mellow is Gesha Ethiopian from the Ethiopian Coffee Co in London (expensive and always in limited supply but worth tracking down).
Posted on: 16 July 2017 by Christopher_M
As as mere moka pot coffee brewer this thread is too hardcore for me.
All I can do is speak up for the coffee at Carluccio's in terms of high street brands. And in my city, good service too.
Posted on: 16 July 2017 by Peakman
At this time of year one of my favourite drinks is cold-brewed coffee. No special equipment is needed (although I use a Hario jug). It hits a very different spot from an espresso shot (which I also brew) and brings out all the flavour of the beans without even a hint of the bitterness that hot water extracts from them, but it won't take the roof of your mouth off! It works particularly well with beans with a strong citrus flavour such as some of the east African varieties, which I find too sharp for my taste when brewed conventionally, but is also good with varieties with more chocolatey notes. And I prefer it at room temperature rather than poured over ice as seems to be recommended on many websites.
Roger
Posted on: 17 July 2017 by ChrisSU
naim_nymph posted:
I wonder how many people are biting their tongues, being too polite to protest at your mention of instant coffee on a thread such as this one! I, too, will confess that I'm partial to the stuff. I'm also very partial to a good strong espresso, but I don't see them as the same drink. After dinner, only espresso hits the spot for me, but in the morning, that would be too much for my taste buds, and that's then I turn to instant. Adding milk first, then hot water, seems to work for me in keeping the too-hot water from the kettle from spoiling the taste.
Posted on: 17 July 2017 by Willy
Cbr600 posted:
Same here except with Asda chosen by you Columbian beans.
Willy.
Posted on: 17 July 2017 by steven2907
Don't know if it's allowed but Costco sell a large 1kg bag of lavazza beans for around £8. Very nice it is to. Tesco and Asda prices seem to fluctuate around the £12+ mark
Posted on: 17 July 2017 by TOBYJUG
For a double espresso, I like what Pizza Express' serves. Always consistently very good.
At the moment my favourite for a French press is Percol organic all day Americano. Not heart stoppingly strong, but very tasty and smooth that can be enjoyed throughout the day.
