New App - New UPnP playlist v New playlist tracks
Posted by: John3 on 26 July 2017
Can anyone explain the difference please?
Posted on: 26 July 2017 by ChrisSU
Not sure I understand the question! Do you mean the difference between a playlist and a play queue?
Posted on: 26 July 2017 by John3
If you touch the three blobs next to a selected track these are two new options or at least renamed options in the new app. Just not sure what the difference is.
Posted on: 26 July 2017 by sjbabbey
I believe that the options are to add the selected track to an existing playlist (if you have already created a playlist its name will appear in a list) or to create a new playlist with the selected track in it.
Any UnP Playlists you have created will appear on the app's homescreen next to your radio presets.
Great, that sort of makes sense. I will try these options out.
