app / android pad issue
Posted by: al9315 on 29 July 2017
Spent the last hour or so getting a little frustrated. My app on my android pad states "app version 2.0"
Trying to find if I have the latest version or not, or if I can do anything to solve my issue?
Switch on pad, launch app uPnP\MinimServer\albums - scroll to album to play etc. all works fine BUT
While listening screensaver closes screen down, or I press button on pad to do the same, when I press again to 'reignite' the screen and choose another album MOST of the time the little wheel just turns and turns, or it launches but 'Minimserver' has vanished & I have to switch pad off & on again to use app
Can anyone tell me where to start looking to resolve this infuriating issue?
My system is NAS > NDX wired via Netgear switch, I do not think it used to be quite as bad as now previously, perhaps I am mistaken?
Thanks for any assistance
Posted on: 29 July 2017 by David Stewart
V2.1.1 of the Android app is available on the Play Store and I understand this has fixed the problem for some people. However my Samsung tablet seems to work okay with my SuperUniti and I'm still running V2.0 at the moment. Could be worth a try for you though! Good luck.
David S
