Constructed DIN to XLR using Mogami W2534 Cable
Posted by: NewNaim16 on 30 July 2017
Following the earlier 272 + 2549 + 300 <https://forums.naimaudio.com/to...300 discussion, kicked off by Huge, at last I got to experimenting with a home made 272 to 250 DIN to XLR cable constructed from Mogami W2534 Quad Microphone Cable. The screen was connected to 0v at the 272 source end and the 4 cores for L + 0v and R + 0v respectively which was physically tricky with so much on 0v.
I wonder if it might have been theoretically better to connect the screen to the 4-pin DIN cable connector case but it's done now. Maybe the 0v pin of the DIN chassis socket is immediately connected to the case, or maybe not, I don't know. The cable is a more convenient 0.6m in length compared with the standard 1m Naim cable.
It's only been used for about 1hr so are still evaluating it but we hear a slight difference in presentation with what might perhaps be described as a more open top end. Whether that's better or not I/we are not yet sure but in any event the change is subtle and nothing like as significant as the difference heard when we tried a Super Lumina DIN to XLR, which we decided not to proceed with.
Next up I'm going to try a simpler construction using a single piece of Mogami W2549 Balanced Microphone Cable but these things take time ...
