hp cables or interconnects?
Posted by: French Rooster on 03 August 2017
hello,
i have the choice to upgrade , for the same total price, my interconnects cables ( between amp and preamp and preamp and nds) or my  hp cables.
The hp cables are apertura tiny ( a little better than naca 5 to my ears): i can go to kharma matrix reference or eventually naim superlumina.
My 2 interconnects are chord signature tuned array: my dealer can take them back if i take chord sarum t ( for nds and between amp/ preamp).
Which choice will give more upgrade in sound quality ? i can't take both and don't want to upgrade other part . Just better hp or better interconnects ?
in each choice the total price is around 4000GBP.
Posted on: 03 August 2017 by French Rooster
i feel that the upgrade on interconnects will give more upgrade in sound quality vs the upgrade in hp cables....but difficult to be sure.
