ios app v 5.7.3
Posted by: jcgraas on 04 August 2017
Some front cover pictures do not display, even after clearing the cache and restarting the app (v5.7.3). I checked with foobar2000 that the front cover picture is well attached. Does not seem to be caused by the size of the picture. Try to "retagg" with foobar2000 : unsuccessfully.
(Sorry for the language errors - native french speaking).
Posted on: 04 August 2017 by Mike-B
The problem is not in the app;  the app will only display what is sent to it, no picture = no picture sent.   If it happens on my system its because my NAS has an indexing problem & I just run a NAS reindex.    Suggest you try that.
Posted on: 04 August 2017 by Scooot
Is anyone else having the app (iOS 5.7.3) hanging on finding rooms.When it does get past that issue I then have to press a ndx symbol on the top of screen.Previously it just opened to my 3  options,music,radio and Spotify.In the last couple of days I have had to uninstall and reinstall the app to get past finding rooms.Any idea would be welcome.
Thanks.
I've had all the above Scooot,  but to be fair 5.7.3 has been pretty good.   Most times on opening it opens straight into into the Home Screen,  sometimes (maybe 1 in 10 or more) it opens to a blank screen with just the Naim logo at the bottom, a second or so later a flash of 'Finding Rooms', then a very short flash of the NDX picture/icon & into Home Screen.
I'm a beta tester & installed more apps than most.  I'm suspicious of reinstalling over an existing app might leave a 'problem' link in place & to prevent this I normally delete the app, then force a restart - press & hold both the Sleep/Wake & Home buttons until you see the Apple logo (about 10 secs)  -  then re-install & set-up your settings preferences.   The restart clears the RAM rubbish that might be causing the problem.  It might not,  but worth a try,  ya never know.
Mike-B posted:
I'm a beta tester & installed more apps than most.  I'm suspicious of reinstalling over an existing app might leave a 'problem' link in place & to prevent this I normally delete the app, then force a restart - press & hold both the Sleep/Wake & Home buttons until you see the Apple logo (about 10 secs)  -  then re-install & set-up your settings preferences.   The restart clears the RAM rubbish that emight be causing the problem.  It might not,  but worth a try,  ya never know.
Cheers Mike,
I will give your suggestions a try and hopefully it will do the trick.
scott
Posted on: 04 August 2017 by jcgraas
Mike-B posted:
Hei Mike, thanks for your message. Reindexing the 35.000 tracks takes approximately 5 full days on my DS416Play; so, I am hesitating to start the process. I have tried the following on a set of tracks : erasing all pictures and reinstalling the cover picture with foobar2000; uninstalling and reinstalling the ios app; I now get the correct display of the cover picture. I will further investigate the subject. Regards.
Bonjour JCGrass,  how is Liege these days??   I spent a some time there back in 1976/7,  a lot of good times & good friends.   I was in Brussels & Ghent 2 weeks ago,  a weekend with old friends, good food & some beers that leave an impression.
I'm no expert on NAS indexing,  but 5 days seems a lot.  I don't have 35000 tracks but my reindex takes around 10 to 15 minutes. My NAS has an automatic indexing system that rarely needs attention, but once in a while, normally when a new album is loaded, a reindex is needed to get the art straight away (it does it without intervention if nothing is done for a few hours)  maybe its just an incremental reindex.
MiIKE-B,
Hopefully you pick this up.Your suggestions above have worked so far so good.Thank you,much appreciated.
scott
Scooot posted:
MiIKE-B,
scott
Hopefully the fix sticks.   :-)
Posted on: 05 August 2017 by nickpeacock
[@mention:71117301701440397] as MikeB says, I think you might be doing a full re-sync, rather than just a re-index.
Posted on: 05 August 2017 by jcgraas
Mike-B posted:
Hello Mike, it's raining today. Should be better tomorrow. In the '70's, Liège was awful; since then the city has changed a lot (positively).
What I did previously was "unmarking" the index for the "/music" directory and "marking" it again > 5 days indexing; in fact, I missed the reindex button; I will give it a try.
Thanks for your support.
nickpeacock posted:
Hello Nick, how do I re-sync (Synology DS416play with "DSM 6.1.3-15152 Update 1"?  Thanks, JC
Posted on: 05 August 2017 by Mike-B
jcgraas posted:
nickpeacock posted:
Ahh  !!!!   a Synology !!!!  same as me.    You don't need to re-sync.  its re-index you need.     Control Panel>Indexing Service>touch 'Reindex'  button    However you need to have already set up your 'Music' folder for indexing.  How to do that is here >>>  https://www.synology.com/en-uk...indexservice_general
Pbew, Mike B got there just in time!
Thanks for the info Mike. Music folder setup was OK.
Posted on: 07 August 2017 by antony d
downloaded from App store 5.7.3 no issues, test flight is only letting me load 5.7.2
so I have ignored this for the moment and emailed in comments on Naim App 5.7.3 is working well pleased to say
Posted on: 07 August 2017 by Simon Frequency
antony d posted:
Hi Antony,
You are correct the last Beta tested was 5.7.2, Naim released an updated vesion to App Store 5.7.3, (linked with to the Atom release) - this is an excellent app and works well.
Simon
