6pack135 failure
Posted by: jon h on 19 August 2017
So last night I sat down to some choons with my mate Alex who has come up for the weekend. (Ex of Beechwood audio in Braintree if anyone remembers back that far)
No tweeters on the DBLs. Both dead.
Get to back to snaxo362, and start moving the cables around. Appears that both 135s driving the tweeters are dead, despite all the lights being on.
Moving speaker cables around and driving the tweeters from the midrange amps (with midrange signal) shows that the tweeters are still working. Note: lift the volume level from off very carefully and slowly when doing this, you are putting midrange energy into a tweeter. You only need a sniff to know they are ok.
Try mid feed via tweeter 135s into mid speakers. Nothing. Clearly it is tweeter 135s that have died. But why are their lights on?
Send a message to Phil@Naim. Moments later he calls me, despite it being past 9pm. After discussions, we remember from deep and distant history that the 135s have protection circuits and they can shut down, leaving the lights on. The only way to reset them is to turn them off, leave them for some minutes, and then bring them back up again.
We try this. Finally the two 135s wake up and full choons are restored.
Kudos to Phil for out of hours support on a Friday evening. Beyond the call of duty.
And boohoo to Naim for not having the instruction manuals for *all* products available on the website. It might have told me in the 135 manual about this trip feature. But who can tell? It seems that only recent manuals are there, which is disappointing
Posted on: 19 August 2017 by NFG
Fair play to Phil there well done for sorting it & I agree it would be useful if Naim had manuals available for its 'legacy' products.
Posted on: 19 August 2017 by ianrobertm
Its a good point - about the older manual. Which has been made on here before - and nothing has happened.....
Glad all six 135's now working.....
Posted on: 19 August 2017 by tonym
Phew! Bet you had the DBLs at your normal volume level Jon. Great service from Phil, as usual.
Posted on: 19 August 2017 by ChrisSU
It would certainly be handy to have a single online source for all Naim manuals, although a google search normally finds one somewhere.
Regarding the 135s, could the shutdown point to an underlying problem somwhere?
Posted on: 19 August 2017 by Richard Dane
I've asked before for the old manuals to be put on the website. Hopefully there's no particular problem in doing so, but I'll find out. I'll drop a gentle reminder when I'm next down at the factory in September.
Posted on: 19 August 2017 by Clive B
I have quite a collection of old style Naim Audio manuals and have found two (so far) on amplifiers, one of which has 'layered' pages. They both describe a situation where the regulated power supply shuts down if more than 18 amps is drawn for >10 microseconds. In this case the power light remains on. This appears to be the case described by Jon. In this event, the instruction given in the manuals is to turn the amplifier off for two minutes, which was precisely the advice offered by Phil.
Posted on: 19 August 2017 by Eoink
Have a look at the downloads section of the Class A website (I don't think I can link to it here). Darran has the manuals for the CBs and olives there.
Posted on: 19 August 2017 by Huge
Wow, that's a horrible scary event, and with the prospect of having to get repair or replacement and the time needed to do it!
Glad it got sorted so easily for you, and much kudos to Phil (even if he doesn't use their speakers).
Posted on: 19 August 2017 by Obsydian
Wow now that's service and knowledge, did he also recommend any wipes (lol) must admit I'd have wet myself with worry.
Reminds I have an old dealer folder something for all the old gear - must find it
Posted on: 19 August 2017 by Pcd
I've downloaded all my Naim manuals and connection guide etc into dropbox with off line viewing worth doing manuals always on hand.
Posted on: 19 August 2017 by analogmusic
but why did both NAP 135 shut down to begin with? Are they in need of a service?
Posted on: 19 August 2017 by Ardbeg10y
Posted on: 19 August 2017 by jon h
Well it was probably related to the piece of state of the art test equipment I was using to measure something connected to the 52... I had probably better stop there before I incriminate myself further...
Posted on: 19 August 2017 by Chris Dolan
Are there different shut down circumstances when the amp shuts down and the power light goes out?
Blown fuse, blown bulb (on early one), blown something...
I was thinking of something a bit more subtle - but I take your point
Posted on: 19 August 2017 by lyndon
A blown bulb won't shut the amp, I'm currently looking at 4 bright green lights and 2 not so green
all is sounding good
back to the original point, I would be more concerned as to why the amp tripped especially as it was the tweeter pair
ive tripped them in the past with briks but they are harder to drive but only the bass amps
surely you would fry the tweeters before tripping the amps ??, once again loads of experience with this when I had the old briks
lyndon
Lyndon, if you trip out the amp and the bulb blows then that would give a scenario where the amp shuts down and the light goes out. But seriously, my point is that if the amp shuts down and the power light goes down then check the mains plug fuse, then the inlet fuse - either of those may have blown. If the latter is the issue then try a replacement, and if that blows then it's time to have the amp checked over by Naim.
Richard
once again I've had a few fuses blow, all on the power amps
either just after serving or re- connecting everything again
if I had a blown fuse which then blew again on replacement then I would get the amp looked at
ive grown to learn these 6 packs can be pretty sensitive and their wiring pretty intricate
once all up and running they are best left alone
lyndon
Posted on: 19 August 2017 by listener72
A question for the learned?
The lights on my 135's don't work.
Despite several replacements, they only last a few weeks.
The 135's are recently serviced, the first few replacement globes were supplied then we just gave up?
Posted on: 19 August 2017 by hungryhalibut
With the lights out, it's less dangerous.
Posted on: 20 August 2017 by analogmusic
Richard
lyndon
Are you using Naim speaker cables?
Posted on: 20 August 2017 by Blackmorec
Hi Jon,
Your 135 lights are on because there's power applied and the amps are live. The output may be disconnected but the rest of the amp is still powered up so simply a safety issue.
For the rest there's something really funky going on. For 2 amps to shut down at the same time is very unusual unless they were both overdriven, which with healthy tweeters would be difficult, given that the amps are only fed tweeter range frequencies from the NAXO and tweeters don't demand or take high current. Shutting down usually happens in the presence of a fault condition but in this case you would need to have the same fault on both channels.
If I was you I would reconfigure my 135s and swap the tweeter and midrange units around (changing both input and output obviously) so you can actually evaluate the quality of sound coming from the current tweeter amps (its really difficult to evaluate an amp based on tweeter performance) and see if the 2 amps give any further problems when connected to the midrange drivers. If they do, you know you have an amp problem, whereas if the new tweeter amps have any further issue you have a speaker problem.
If nothing more happens then its coincidence that both amps shut down at the same time, highly unlikely.
You may want to check with Naim is there are other conditions beyond excess current that can cause 2 amps to shut down simultaneously, excess heat for example.
Posted on: 20 August 2017 by jon h
I think me doing rude things with some test equipment was probably the fault cause... sending impulses through the system with the volume accidentally raised wasnt wise... and thank goodness the dibble tweeters are reasonably robust, given there are no spares.
