naim headline nac 282
Posted by: pino on 23 August 2017
Hello to all
Please I need help.
I can not connect my naim headline / napsc to naim nac 282 preamp.
Can you send me a link diagram?
thank you so much
Posted on: 23 August 2017 by Richard Dane
Pino, it's very simple.  You just connect the two pin connector from the NAPSC into the back of the Headline.  Then connect the Headline signal cable with the DIN5 into one of the NAC282's tape IN/OUT sockets.  Power up the NAPSC/Headline, select the source you wish to hear on the bottom REC bank.  Ensure the REC circuits are not muted.
Posted on: 23 August 2017 by pino
thank you so much
