file dsd
Posted by: pino on 24 August 2017
Hello to all.
How can i play dsd files on my naim system?
thank yo
Posted on: 24 August 2017 by Mike-B
Hi, Can you tell us what streamer you have & also the NAS make & UPnP software.
Posted on: 24 August 2017 by pino
nd5xs
jriver
ND5 plays DSD64 providing it has firmware version 4.3 or later (when DSD was embodied) DSD64 is also called 2.8, referring to the single bit sampling rate of 2.8224 MHz ----- this is '64' times the CD sampling rate of 44.1 kHz
TBH I know very little about JRiver. I know it can handle DSD but I believe it needs setting up to do this. If yours is not already done & you need to know how, I suggest you go to JRiver to get the instructions on this. I see instructions are published on www but I can't know which/what is applicable to your JRiver.
