Oppo UDP-203 into Naim DAC volume level
Posted by: nbpf on 24 August 2017
I have an Oppo UDP-203 directly connected to my Naim DAC via digital SPDIF optical and electrical. It works fine but the volume level is much higher than when the DAC is connected to the optical SPDIF output of the TV or to the electrical SPDIF output of my USB->SPDIF bridge.
Any idea how to get the inputs of 203, TV and USB->SPDIF bridge roughly at the same level? Thanks, nbpf
Posted on: 25 August 2017 by steven2907
If you look at page 62 in the owners manual it tells you how to adjust the output volume.
Posted on: 25 August 2017 by nbpf
steven2907 posted:
Thanks but the "Output Volume > Variable" setup of page 62 only affects the analog outputs, not the digital outputs.
