Blister on Vinyl
Posted by: Smithfire on 25 August 2017
Hi peeps
Just received an LP that I puchased from a seller in France only to find a small blister on the playing surface. Only raised by a small amount but deffo blistered.
Anyone else come across this before?....its a new unopened 180g pressing.
Clive
Posted on: 25 August 2017 by Tony2011
Untitled
These things happen. Brand new, sealed, supposed to be red vinyl. Ask seller for a replacement.
Posted on: 25 August 2017 by Smithfire
Seller in france so probably economically unviable. Could contact the Manufacturer?
Seller should cover return costs, depending where you bought it from. I doubt manufacturer will do anything about it but always worth trying. Contact seller first and try to sort it out amicably.
