Muso qb fails set up
Posted by: ray sheldon on 28 August 2017
Hi all,
Anyone know how to connect your tablet or phone to a muso qb to set it up?
The app works fine for the NDX but won't connection to muso to enable WiFi.
Obviously I've clicked set up new device and selected the right product.
I have a purple flashing lights on rear of unit and pressing next on app as instructed but it won't connect.
I've tried plugging in network cable but it's telling me that's it's already connected to a network. So I've reset the device several times and removed the network cable as instructed to no avail.
Posted on: 28 August 2017 by ray sheldon
OK now, Naim missed something simple off the app instructions. .....'open up WiFi on your tablet or phone, see muso and click connect'
Posted on: 28 August 2017 by Pcd
ray sheldon posted:
Ray, glad its sorted did the same thing myself a strange omission from the set up menu ?
Thanks. Another source of annoyance  (no pun intended) is that it seems you can't stream WAV files over WiFi. Which makes the purchase pointless as I wanted to stream from my unitiserve to upstairs.
Posted on: 28 August 2017 by ltaylor
ray sheldon posted:
I'm not sure that is true. I can stream wav files to mine, including high definition files. However you do need a good wifi signal for this. In my case I have an Apple Airport connected by ethernet to a mac mini running Asset. This can output DSF files as wav since my UQ2 and QB cant deal with these in their native format. I normally connect by ethernet but I tested wifi on my QB and it works fine for me.
Thanks. Anyway I have uintentionally started a thread on this over on the hifi forum.
It won't be long before the usual mob pick up on this and start throwing their toys out of the pram lol.
Posted on: 28 August 2017 by Claus-Thoegersen
Quality wifi or you will post a lot negative on the forum in months to come.
Claus
