External mics for a Nikon DSLR
Posted by: Kevin-W on 05 September 2017
Dear all
I need to get a good external mic (one that sits on the camera hotshoe) terminating either in a mini jack or mini USB. To be used for filming YouTube clips and ambient sounds/ibnterviews etc - doesn't have to be super hi fi quality but obviously much better than the camera's built-in mic.
I have about £200 to spend - absolute max. Any help appreciated!
Thanks x
Posted on: 05 September 2017 by winkyincanada
For £200 you have a lot choice. The Rode seems to get great reviews....
https://www.amazon.com/Rode-VM...M/ref=dp_ob_title_ce
Posted on: 05 September 2017 by Kevin-W
Cheers Winky - that looks a good 'un. Nice and compact too. Will investigate.
Posted on: 05 September 2017 by jon h
rode
