Looking for streaming audion advice
Posted by: Morgs on 05 September 2017
This may seem like a newbie question but here goes. My primary system is a NAC282 with Linn LP12 and CDX as the main inputs. I also have a Naim MuSo in another room I use for stream audio from a Synology NAS. I want to be able to stream the FLAC files I have on the NAS to the Naim system but not sure how to do this. I was looking at buying a used Naim DAC but not sure what to use to stream the data from Synology to DAC. I have been looking at the new Uniti components but again not sure which option makes most sense.
Any ideas, suggestions, experience to share?
Thanks!
Posted on: 05 September 2017 by nickpeacock
Don't worry, Morgs, we're here to help!
With the system you have, one simple route is a Naim streamer (ND5 XS or, better, NDX), which will act as another source and connect to your 282. Both have an internal DAC; both will read the music from your NAS (preferably via an ethernet cable between your router and whichever streamer you choose, alternatively via wifi) and play it; both are excellent.
Lots of other methods, but this is worth looking at.
Posted on: 05 September 2017 by Morgs
Thanks for the fast response. So an external DAC, other than for sound quality improvements, is not required?
Posted on: 05 September 2017 by Adam Zielinski
Correct.
Naim DACs are seen as upgrades to primiary digital sources like CD playes and streamers.
Given you already have 282 and CDX, I would recommend an NDX. If purchasing new is not your cup of tea, there should be some pre-loved ones on the market.
Posted on: 05 September 2017 by Pcd
Agree with Adam.
Thanks to everyone that responded. After brief consideration of NAC272 now on the hunt for a lightly used NDX.
Good decision!
