NAC282 "static" when using volume/balance controls
Posted by: Morgs on 05 September 2017
Good morning from sunny southern California. I recently moved from Florida to California and had my stereo in storage for about 9 months while our new home was completed. I recently put everything together and I now have a problem which I think is linked to my Pre Amp. My system setup is NAC 282/NAP250 -> SBLs - Inputs CDX2/XPS and Linn LP12 + Armageddon. There is a static/crackle on both channels when I use either the volume or balance controls. There is also occasional "static" on the left channel when I first play something but this seems to diminish after listening for a while.
Any ideas what this might be. Does the 282 need a service? Anything else I should look at?
Thanks in advance.
Posted on: 05 September 2017 by stuart.ashen
Hi Morgan,
I had the same problem on my 252. Sent it to Naim for a service and they replaced the volume pot inclusive of the service cost. Wonderful service if you ask me.
Before you do that though, press mute and give them a few full rotations in case it clears up.
Stu
Posted on: 05 September 2017 by Richard Dane
Morgs, before contacting Naim US service I would switch off and careful make and re-make all the connections on SNAICs, interconnects etc.. and see whether that fixes things.
Posted on: 05 September 2017 by Simon-in-Suffolk
It could be dirt in the pot... if it doesn't clear by wiping the pot severeal times from end to end, then a service may loom. There are special sprays specifically for cleaning pots, but unless you know what you are doing might be best to use a pro.
Posted on: 05 September 2017 by ryder.
I experienced the same thing with my NAC 202 few years ago. There was intermittent static sound from the speakers when the music was playing or when it's completely quiet ie. no music playing. It turned out to be a dirty pot. After the pot was cleaned the static sound was completely gone. I had someone do it for me as I am quite hopeless at these things.
