Atom, Nova refuses to play Tidal - Solution
Posted by: Simon Frequency on 09 September 2017
If you have been unable to get your Atom or Nova to play Tidal read on this may help you.
My Atom has been great, however whilst everything worked, the App could see my Tidal account and music, however when I press play on the App nothing would happen (just to confirm Tidal worked fine on my NDS).
Follow work with my dealer and Naim support, we found the cause and solution was easy.
My Tidal password used a part of the extended character set e.g. !"£$%^&*#, by resetting the password to just upper and lower case A-Z and number characters, the Atom and Nova played Tidal without any problems.
If you find yourself in this place then try a Tidal password reset to use the core character set and see it this fixes it.
I have raised this a issue with Naim.
Simon
