Add Tube preamp to Naim Nait 5si, Harbeth m30.1 combo
Posted by: RaghuV on 09 September 2017
Hello,
I scratched an itch and bought a pair of used rosewood Harbeth 30.1 for 3500 dollars. If I was looking to try some tube sound, could I look to add a tube Pre-amp to the Naim Nait 5si? Any suggestions on Pre-amps?
Thanks.
Posted on: 09 September 2017 by mudwolf
Tube pre for a new turntable and vinyl collection does wonderful things.
Posted on: 09 September 2017 by French Rooster
RaghuV posted:
Hello,
Thanks.
you want to bypass the preamp section of the nait5 and use a tube pre instead?   the only preamp i know that works fine with naim amp is ear yoshino tube pre, i have the ear 912 with nap 300dr.  Perhaps you can find a used ear 864....   audio research should work too, but i have not tested.
